dieselEngineFoam 1.6ext Parallel
Old   April 11, 2013, 17:11
Default dieselEngineFoam 1.6ext Parallel
ris
ri
ris is on a distinguished road
Has anyone managed to get dieselEngineFoam working in parallel with mesh motion(specifically piston compression-expansion)? It seems that every dieselEngineFoam in every version of OpenFOAM is plagued with the mpi crash at injection of particles. I know sprayEngineFoam has problems via this bug report: http://www.openfoam.org/mantisbt/view.php?id=577.
ris.
ris is offline   Reply With Quote
Old   June 15, 2013, 12:19
Martin Novák
novakm is on a distinguished road
Is there any updates of the state of the topic?
novakm is offline   Reply With Quote
Old   June 17, 2013, 02:33
Karl-Johan Nogenmyr
kalle is on a distinguished road
No news, AFAIK. However, I do use the fix I suggested in the bug report on a daily basis. It works fine if you do not try 2D cases... I am using 2.2.x.
Just get rid of all calls (several) to:
meshTools::constrainToMeshCentre
meshTools::constrainDirection
in
InjectionModel.C
KinematicParcel.C
I though the old lagrangian library did work in parallel with mesh motion?
K
kalle is offline   Reply With Quote
Old   June 17, 2013, 04:14
Martin Novák
in
InjectionModel.C
KinematicParcel.C
K
Thanks for your reply I am very grateful for this info. I will keep this information in my mind
l
K
I can not tell, because I don't know. Spray in ICEs is my final goal.
I have reached a problem with attachDetach in parallel in accordionEngineMesh class (OF-ext) already . It drives me crazy now. Therefore I have asked about the parallelization of the "final chapter", in order to know, if it worth the spleepless nights I have already had.
Sorry about my english. I am really tired
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
Can not run OpenFOAM in parallel in clusters, help! ripperjack OpenFOAM Running, Solving & CFD 5 May 6, 2014 15:25
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
