April 24, 2013, 02:10 |
problem for specifiying refrence cell
rehan
Rep Power: 13 |
hello Foamers,
i am modeling a simple channel flow using the interFoam just like the waterchannel tutorial provided in the openfoam..so when i chnged the property of walls to empty for front and back walls...it gives the following error as i am a newbee i cant understand this... FOAM FATAL IO ERROR: Unable to set reference cell for field p Please supply either pRefCell or pRefPoint file: /home/user/OpenFOAM/user-2.2.0/run/squareBump12/system/fvSolution.PIMPLE from line 68 to line 74. From function void Foam::setRefCell ( const volScalarField&, const volScalarField&, const dictionary&, label& scalar&, bool ) in file cfdTools/general/findRefCell/findRefCell.C at line 125. please help.. |
Cell Reynolds Number | laliong | Main CFD Forum | 12 | September 17, 2019 03:18 |
Problem calcualting the mass flow entering each cell | javiercran | FLUENT | 0 | May 31, 2012 15:24 |
Negative cell volume problem in-cylinder | ziani.lotfi | FLUENT | 0 | April 11, 2012 07:54 |
CHT cell layer thickness problem | Arnab | Siemens | 1 | March 13, 2005 08:36 |
Baffle cell problem in shock tube | AB | Siemens | 4 | November 15, 2004 08:44 |
