unsteady mixing of three liquids with OpenFOAM
Old   February 13, 2013, 09:59
Default unsteady mixing of three liquids with OpenFOAM
Mihai Pruna
mihaipruna is on a distinguished road
I would like to solve this problem in a time dependent matter.
Which solver is the best? Does anyone have an example case?
Thanks!
mihaipruna is offline   Reply With Quote
Old   February 13, 2013, 13:59
Mihai Pruna
I guess interMixingFoam and the dambreak tutorial in that folder are a good start?
Old   February 13, 2013, 16:45
Mihai Pruna
on second thought, interfoam might not work as it can support only two miscible fluids ...
Old   February 14, 2013, 07:12
Jibran
Jibran is on a distinguished road
You can try multiphaseInterFoam.
Description:
Solver for n incompressible fluids which captures the interfaces and includes surface-tension and contact-angle effects for each phase.
Just a correction, interfoam doesnot support miscible liquids.
Description:
Solver for 2 incompressible, isothermal immiscible fluids using a VOF(volume of fluid) phase-fraction based interface capturing approach.
Jibran is offline   Reply With Quote
Old   May 6, 2013, 06:20
Albrecht vBoetticher
vonboett is on a distinguished road
actually, you will have to extend interMixingFoam to three mixing phases.
vonboett is offline   Reply With Quote
Incompressible, miscible mixing of two fluid stream OpenFOAM Nishchal OpenFOAM Running, Solving & CFD 6 October 9, 2019 06:55
how to handle liquids in Openfoam soonic OpenFOAM Running, Solving & CFD 1 July 30, 2013 06:00
Mixing task in OpenFOAM TomKopp OpenFOAM Post-Processing 0 October 7, 2012 04:37
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Summer School on Numerical Modelling and OpenFOAM hjasak OpenFOAM 5 October 12, 2008 13:14
