interDyMFoam "time step continuity errors"
Old   May 2, 2013, 09:46
Default interDyMFoam "time step continuity errors"
kilroy's Avatar
kilroy is on a distinguished road
Hello all,
I am having problems with my "waveDyMFoam" which I modified from "interDyMFoam". I am trying to run a simple 2D case where a box is floating on the water under the effect of waves. The video of the case can be seen here:
https://www.youtube.com/watch?featur...&v=YKbj_7JMRl8
Also the case can be downloaded from here:
https://sites.google.com/site/jordim...edirects=0&d=1
At first the case was not running because of some missing schemes in the "fvSchemes" file. So, I added the following lines under "divSchemes" section:
div((muEff*dev(T(grad(U))))) Gauss linear;
div((nuEff*dev(T(grad(U))))) Gauss linear;
When I try to run the case, I get the following errors:
sixDoFRigidBodyMotion constraints converged in 1 iterations
Constraint force: (0 0 0)
Constraint moment: (0 0 0)
Centre of mass: (10.3657 0.00896592 0.05)
Linear velocity: (0.169457 0.0262615 3.6077e-17)
Angular velocity: (-3.19807e-28 -1.37522e-26 -5.1003e-12)
GAMG: Solving for cellDisplacementx, Initial residual = 0.000224045, Final residual = 8.12868e-06, No Iterations 2
GAMG: Solving for cellDisplacementy, Initial residual = 0.000224045, Final residual = 8.12868e-06, No Iterations 2
Execution time for mesh.update() = 0.23 s
time step continuity errors : sum local = 5.05277e-05, global = -3.01844e-19, cumulative = -5.40294e-08
GAMG: Solving for pcorr, Initial residual = 1, Final residual = 8.97864e-08, No Iterations 17
GAMG: Solving for pcorr, Initial residual = 0.250457, Final residual = 5.28244e-08, No Iterations 15
time step continuity errors : sum local = 8.53279e-05, global = -1.02447e-11, cumulative = -5.40397e-08
MULES: Solving for alpha1
Phase-1 volume fraction = 0.666764 Min(alpha1) = -1.93586e-23 Max(alpha1) = 1
DILUPBiCG: Solving for Ux, Initial residual = 0.0130186, Final residual = 1.17418e-10, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.0946691, Final residual = 7.58036e-11, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.261841, Final residual = 5.56369e-08, No Iterations 12
GAMG: Solving for p_rgh, Initial residual = 0.000997295, Final residual = 4.38728e-08, No Iterations 7
time step continuity errors : sum local = 7.35319e-21, global = -4.08938e-21, cumulative = -5.40397e-08
GAMG: Solving for p_rgh, Initial residual = 0.000600283, Final residual = 5.20561e-08, No Iterations 6
GAMG: Solving for p_rgh, Initial residual = 0.00035003, Final residual = 4.53092e-08, No Iterations 5
time step continuity errors : sum local = 7.67551e-21, global = 6.55771e-21, cumulative = -5.40397e-08
GAMG: Solving for p_rgh, Initial residual = 0.000171914, Final residual = 7.8525e-08, No Iterations 4
GAMG: Solving for p_rgh, Initial residual = 5.06367e-05, Final residual = 6.19844e-09, No Iterations 6
time step continuity errors : sum local = 1.04979e-21, global = 1.00984e-21, cumulative = -5.40397e-08
ExecutionTime = 47953.3 s ClockTime = 48046 s
Interface Courant Number mean: 2.38452e-06 max: 0.00400263
Courant Number mean: 0.000200405 max: 0.425284
deltaT = 2.62873e-13
--> FOAM Warning :
From function Time:perator++()
in file db/Time/Time.C at line 1029
Increased the timePrecision from 14 to 16 to distinguish between timeNames at time 12.8093
Time = 12.80933457039102
Linear velocity: (0.169262 0.026284 3.60775e-17)
Angular velocity: (-3.19814e-28 -1.37523e-26 -5.10294e-12)
GAMG: Solving for cellDisplacementx, Initial residual = 0.000221903, Final residual = 8.00376e-06, No Iterations 2
GAMG: Solving for cellDisplacementy, Initial residual = 0.000221903, Final residual = 8.00376e-06, No Iterations 2
time step continuity errors : sum local = 5.01594e-05, global = -1.26375e-19, cumulative = -5.40397e-08
GAMG: Solving for pcorr, Initial residual = 1, Final residual = 8.65576e-08, No Iterations 18
GAMG: Solving for pcorr, Initial residual = 0.181331, Final residual = 5.39143e-08, No Iterations 15
time step continuity errors : sum local = 7.78955e-05, global = -1.19518e-11, cumulative = -5.40516e-08
Phase-1 volume fraction = 0.666764 Min(alpha1) = -1.88721e-23 Max(alpha1) = 1
DILUPBiCG: Solving for Ux, Initial residual = 0.0129951, Final residual = 6.3627e-11, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.0946374, Final residual = 9.16735e-11, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.205321, Final residual = 7.70156e-08, No Iterations 11
GAMG: Solving for p_rgh, Initial residual = 0.000734827, Final residual = 3.76525e-08, No Iterations 7
time step continuity errors : sum local = 3.98678e-21, global = -2.59775e-22, cumulative = -5.40516e-08
GAMG: Solving for p_rgh, Initial residual = 0.00041682, Final residual = 7.59192e-08, No Iterations 5
GAMG: Solving for p_rgh, Initial residual = 0.000186038, Final residual = 4.30575e-08, No Iterations 5
time step continuity errors : sum local = 4.24988e-21, global = -3.26612e-21, cumulative = -5.40516e-08
GAMG: Solving for p_rgh, Initial residual = 0.000101912, Final residual = 4.99173e-08, No Iterations 5
GAMG: Solving for p_rgh, Initial residual = 3.9727e-05, Final residual = 8.3358e-09, No Iterations 6
time step continuity errors : sum local = 8.22266e-22, global = -6.35014e-22, cumulative = -5.40516e-08
ExecutionTime = 47954.4 s ClockTime = 48047 s
Interface Courant Number mean: 2.30322e-06 max: 0.0032262
Courant Number mean: 0.000207624 max: 0.544706
deltaT = 1.20649e-13
Time = 12.80933457039114
Linear velocity: (0.169412 0.0262994 3.60779e-17)
Angular velocity: (-3.19822e-28 -1.37522e-26 -5.10071e-12)
GAMG: Solving for cellDisplacementx, Initial residual = 0.00021926, Final residual = 7.84774e-06, No Iterations 2
GAMG: Solving for cellDisplacementy, Initial residual = 0.00021926, Final residual = 7.84774e-06, No Iterations 2
time step continuity errors : sum local = 3.57512e-05, global = 7.09289e-19, cumulative = -5.40516e-08
GAMG: Solving for pcorr, Initial residual = 1, Final residual = 7.51115e-08, No Iterations 20
GAMG: Solving for pcorr, Initial residual = 0.121942, Final residual = 9.90107e-08, No Iterations 14
time step continuity errors : sum local = 8.06169e-05, global = -3.4904e-11, cumulative = -5.40865e-08
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4 void Foam::MULES::limit<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::zeroField const&, Foam::zeroField const&, double, double, int, bool) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, double, double) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
in "/home/meta/OpenFOAM/root-2.2.0/platforms/linux64GccDPOpt/bin/waveDyMFoam"
#7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
And my analysis crashes around the 12th second. I checked my mesh and everything seemed ok to me.
Do you have any idea what may be the cause of that problem?
Thank you very much for your time and help.
Kilroy
kilroy is offline   Reply With Quote
Old   May 4, 2013, 03:17
T. Chourushi
Tushar@cfd is on a distinguished road
Originally Posted by kilroy View Post
Hello all,
Kilroy
Your deltaT is decreasing during each time step. For running transient solver you need to be extra careful with Co, deltaT.
I think the following link will be useful to you as you are working with problems related to interFoam solver:
http://www.cfd-online.com/Forums/ope...goes-1e14.html
Tushar@cfd is offline   Reply With Quote
Old   May 6, 2013, 09:44
kilroy's Avatar
Tushar,
Right now I am running the simulation with fixed time step. Hope it will converge this time.
I will let you know.
Kilroy
Old   May 6, 2013, 17:11
kilroy's Avatar
Running the simulation with fixed time step didn't help
I tried a time step size of 0.001 sec. but the simulation crashed even earlier than before this time. Now I am trying 0.0001 sec. but it is taking too much time.
Any other suggestions?
Kilroy
Old   May 7, 2013, 01:39
T. Chourushi
Kilroy
What is your max Co number ? try to reduce it to <1.
Also, set maxdeltaT value to be around <0.001, and try running the same.
As you are decreasing time step size, then it is obvious that it will take more time in computation.
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
MRFSimpleFoam wind turbine case continuity error ysh1227 OpenFOAM Running, Solving & CFD 1 August 16, 2016 09:25
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
