compressible low speed channel flow
Old   May 8, 2013, 12:27
Default compressible low speed channel flow
Ali
-Ali is on a distinguished road
Hi all
I am trying to simulate the low Reynolds (say Re=5) mass driven compressible flow in a rectangular microchannel. I used rhoCentralFoam with the following BC:
Pressure:
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 101315;
Velocity:
inlet
type fixedValue;
value uniform (0.79473 0 0);
outlet
type zeroGradient;
However, the results are not physical for example a reverse flow appears at the inlet!
I am wondering if I should use another solver or other BC?
Is there anyone who can help me?
Thanks.
-Ali is offline   Reply With Quote
Old   May 9, 2013, 00:25
Ali
Hi
I am really confused with the simple problem of straight rectangular channel.
I need to solve the flow but really cant find out what the problem is with the setting of the openFoam. I would be greatly thankful if any body has a promising feedback.
Old   May 9, 2013, 01:26
Nima Samkhaniani
nimasam is on a distinguished road
Dear Ali
@ inlet, fixed your pressure and @ outlet, assign a zeroGradient
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   May 9, 2013, 03:54
HECKMANN Frédéric
fredo490 is on a distinguished road
The problem in your case is that the pressure gradient in your domain is too small. You should work with a solver using a "relative pressure".
Your case reminds me this topic: http://www.cfd-online.com/Forums/ope...on-fluent.html
You can also try another solver. rhoSimplecFoam / rhoPimpleFoam
Edit: put your full case here. Maybe your problem is not located in the boundary conidtion.
fredo490 is offline   Reply With Quote
Old   May 9, 2013, 04:35
Ali
Dear Nima
Thanks a lot for your kind reply.
I changed the BC as you said but the solution is wrong again.
I also set the inlet pressure somewhat higher that the interior to avoid any back flow but surprisingly this leads to a stronger reverse flow.
can you please help me on this?
Old   May 9, 2013, 04:54
HECKMANN Frédéric
By the way, why do you need a compressible flow ?
And try to post your full case. Maybe you made a mistake somewhere else.
Old   May 9, 2013, 05:03
Ali
Dear Frédéric
Thanks for your comment. It really make scene and I think OF has some problem in solving the pressure field. Actually, I am new with OF and so I supposed rhoSimplecFoam / rhoPimpleFoam are for turbulent flow and cannot be used for low speed laminar cases.
My case is a compressible flow throw a microchannel at Re~1. Here are the details of my mesh and BC and solver settings.
It is a great help to me if you can show me the way.
Many many Thanks.
blockMeshDict:
[QUOTE][]
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 5e-5;
vertices
(0 0 0)
(10 0 0)
(10 1 0)
(0 1 0)
(0 0 1)
(10 0 1)
(10 1 1)
(0 1 1)
blocks
hex (0 1 2 3 4 5 6 7) (151 51 1) simpleGrading (1 1 1) // (141 51 51) simpleGrading (3292 0.047 0.047)
edges
boundary
inlet
type patch;
faces
(0 3 7 4)
outlet
type patch;
faces
(1 5 6 2)
bottom
type symmetryPlane;
faces
(0 4 5 1)
top
type patch;
faces
(3 7 6 2)
front_back
type empty;
faces
(0 1 2 3)
(4 7 6 5)
mergePatchPairs
thermoPhysicalProperties:
[QUOTE][
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object thermophysicalProperties;
thermoType ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>;
mixture
specie
nMoles 1;
molWeight 28.96;
thermodynamics
Cp 1007;
Hf 0;
transport
mu 1.846e-05;
Pr 0.711;
turbulenceProperties:
[QUOTE][
FoamFile
version 2.0;
format ascii;
class dictionary;
object turbulenceProperties;
simulationType laminar;
Pressure BC:
[QUOTE][/*--------------------------------*- C++ -*----------------------------------*\
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 101315;
boundaryField
inlet
type fixedValue;
value uniform 111315;
outlet
type zeroGradient;
bottom
type symmetryPlane;
top
type zeroGradient;
front_back
type empty;
Temperature BC:
[QUOTE][//*--------------------------------*- C++ -*----------------------------------*\
FoamFile
version 2.0;
format ascii;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
inlet
type fixedValue;
value uniform 300;
outlet
type zeroGradient;
bottom
type symmetryPlane;
top
type fixedValue;
value uniform 350;
front_back
type empty;
Velocity BC:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0.79473 0 0);
boundaryField
inlet
type fixedValue;
outlet
type zeroGradient;
bottom
type symmetryPlane;
top
type fixedValue;
value uniform (0 0 0);
front_back
type empty;
controlDict:
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application rhoCentralFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 1e-02;
deltaT 1e-6;
writeControl adjustableRunTime;
writeInterval 1e-5;
cycleWrite 0;
writeFormat ascii;
writePrecision 10;
writeCompression off;
timeFormat general;
timePrecision 6;
adjustTimeStep yes;
maxCo 0.2;
maxDeltaT 1;
fvSchemes:
| \\ / O peration | Version: 2.1.0 |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
fluxScheme Kurganov;
//fluxScheme Tadmor;
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(tauMC) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
reconstruct(rho) vanLeer;
reconstruct(U) vanLeerV;
reconstruct(T) vanLeer;
//reconstruct(rho) upwind;
//reconstruct(U) upwind;
//reconstruct(T) upwind;
snGradSchemes
default corrected;
fv solution:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
"(rho|rhoU|rhoE)"
solver diagonal;
U //"(U|e)"
solver smoothSolver;
smoother GaussSeidel;
nSweeps 2;
tolerance 1e-09;
relTol 0.01;
e
nSweeps 2;
tolerance 1e-10 relTol 0;
h
$U;
tolerance 1e-10;
relTol 0;
Old   May 9, 2013, 05:11
HECKMANN Frédéric
Instead of copying all the file here, you can actually upload them. There is a function "Attach Files" just below the submit button.
rhoSimplecFoam can be either turbulent or laminar. You can use k-epsilon, k-omega, Sparlat Allmaras, or laminar. And if you use rhoPimpleFoam, you can use all those model and even LES.
The official description is:
rhoSimplecFoam Steady-state SIMPLEC solver for laminar or turbulent RANS flow of compressible fluids
So yes, this solver can do the job...
Old   May 9, 2013, 05:15
HECKMANN Frédéric
I'm not familiar with rhoCentralFoam but I don't think it is suitable for you. rhoCentralFoam is a density based solver (which was primarily designed for supersonic flow) while rhoSimplecFoam is a pressure based solver (which was primarily designed for subsonic flow).
Old   May 9, 2013, 05:17
Ali
Dear Frédéric
I have solved the flow with an incompressible CFD code but whereas the pressure drop in microchannels are considerable and also there is a considerable temperature gradient in my problem, I am curious to see what happen if I use a compressible solver. Actually I have to compare my results with those of compressible case.
Old   May 9, 2013, 05:29
Ali
Thanks for you comments dear Frédéric
(I am a row new member in this site )OK; I will try the rhoSimplecFoam hope it work.
Then I will tell you about the results.
Again thanks for your kind informative comments.
Old   May 9, 2013, 07:40
HECKMANN Frédéric
Originally Posted by -Ali View Post
Dear Frédéric
Well, you didn't mention that before... I'm not familiar with micro channels. Where does the heat come from ?
Also, are you sure your flow is really 100% laminar ? How is the flow at the inlet of your simulation ? Does it come from a "tube", how long ? If yes, you might need to consider the turbulence of the upstream flow.
The problem in micro channel, if I remember well, is that the boundary layers tend to meet at the middle of the channel. Maybe a fine mesh with a k-omega SST model can handle this problem. You might need to compare two simulations (laminar vs k-omega sst).
channel flow, compressible solver, low speed, mass driven, rhocentralfoam
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Compressible Flow Modelling? yeo FLUENT 4 March 7, 2003 07:08
compressible channel flow sky Main CFD Forum 0 December 5, 2002 09:05
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
