[stressAnalysis] Residual plot for OpenFOAM-ext problem. |
July 3, 2014, 15:52 |
#21 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
PyFoam should parse the stuff there Which version of PyFoam do you use?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
July 9, 2014, 16:35 |
#23 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I had a look. Some of the solid-solvers in foam-extend-3.x (I assume you're using one of those from the link you posted. Yourself you didn't say what you're using) have residual-output that is slightly different from the normal form and therefor the regular expression that looks for residuals is confused. You'll have to say which solver you're using (preferably also a tutorial case to reproduce). Then I can say whether it is possible to fix it (for the solvers that add information to the residual line I recommend a customRegexp)
July 11, 2014, 10:48 |
#24 | |
July 12, 2014, 14:42 |
#25 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The other problem is that this solver has a non-standard format for the time ("Time: 1") and PyFoam therefor can not tell when one time-step starts. The good news is that this is configurable. Check with pyFoamDumpConfiguration.py: Code:
[SolverOutput] timeregexp: ^(Time =|Iteration:) (.+)$ Code:
[SolverOutput] timeregexp: ^(Time =|Iteration:|Time:) (.+)$
July 14, 2014, 07:38 |
#26 | |
July 14, 2014, 08:36 |
#27 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
You're welcome. By "untested" I meant: the feature works. The regular expression I wrote is untested
Foam::error::printStack after large bounding epsilon events | StoneCFD727 | OpenFOAM Running, Solving & CFD | 1 | January 1, 2018 17:04 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
settlingFoam unstable? | bendel_boy | OpenFOAM Running, Solving & CFD | 38 | July 8, 2016 05:07 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
