3D simulation blowing up
Old   November 17, 2019, 05:37
Default 3D simulation blowing up
Quinten
chengineer is on a distinguished road
Dear all,
I am working on a project for three phase flow in a bubble column with overlying oil layer.
Using multiphaseEulerFoam, I first validated the equations in 2D (of6).
Now, I want to switch over to 3D. I created a "fine" (800k cells) and "very fine" (+-2M cells) mesh in salome. The timestep is set at 5e-7, maxCo is 0.5.
The problem I am experiencing is that, using the "very fine" mesh, the timestep rapidly decreases towards e-30 (for an adjustable timestep) or the simulation stops after about 40 iterations (for fixed timestep). Similar issues are found for the "fine" mesh, but a larger amount of iterations is achieved.
From the results, I can see that the pressure blows up.
Since I am a relatively new user, I have no clue what could be the reason for this sudden pressure increase.
Did anyone experience similar issues, or can someone give me advice on how to resolve this problem?
Thank you!
Quinten
chengineer is offline   Reply With Quote
blowing up, bubble column, pressure
Transient Simulation in CFX ashtonJ CFX 1 September 28, 2018 01:18
Convergence Problem - Transient Simulation gemxx Main CFD Forum 0 July 15, 2018 09:36
Mapping Field Data for Mesh Regions from Another Simulation veterator OpenFOAM Pre-Processing 1 July 10, 2018 05:28
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 02:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 15:06
