July 25, 2019, 06:13 |
Time dependent setFields
James
Rep Power: 12 |
Kindly give me an insight on how to set time dependent setFields utility?
Say, I want to keep generating water in the circular computational domain (say every 5 sec) when simulation time is for 60 Sec. (as shown in figure) of dambreak. How do we change the conservation of mass equation when mass is being constantly added? Thanks! |
July 25, 2019, 08:50 |
Rep Power: 8 |
you have to introduce source terms in your computational domain via fvOptions framework.
setFields is a utility to initialize your fields. |
July 30, 2019, 12:03 |
James
Rep Power: 12 |
Thank you for your prompt reply Evren.
Based on twoPhaseEulerFoam/laminar/injection, I modified fvOption file and kept it inside interfoam/damBreakTutorial/constant folder. Simulation runs fine but I don't see any injection of the mass term (Water) in the specified point. What could I be doing wrong? The fvOptions code is as: FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // injector1 { timeStart 0.1; duration 0.5; selectionMode points; points ( (0.1 0.35 0.0) ); } options { massSource1 { type scalarSemiImplicitSource; scalarSemiImplicitSourceCoeffs { $injector1; volumeMode absolute; injectionRateSuSp { mixture:rho.water (1 0); // kg/s // } } } } |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 41 | August 23, 2023 02:48 |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
