Numerical instabilities due to temperature at inlet
Old   June 18, 2013, 08:31
Default Numerical instabilities due to temperature at inlet
Matze7 is on a distinguished road
Hi Foamers,
I have a problem with my simulation case.
I want to simulate a flow through a cube with 1.5 m/s.
The temperature of the cube is 1373 K, the inflow should have 1573 K.
I use buoyantSimpleFoam and kEpsilon.
If I set the inlet-temp. to 1373 K everything works fine.
If i set the inlet.-temp. to 1573 K numerical instabilities at the inlet occure. The temperature in some areas rises quite high, respectively drops.
I have no idea why, I guess something in my BCs is wrong.
The BCs are:
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 1.505e-4;
boundaryField
    baseleft
        type            compressible::epsilonWallFunction;
        value           uniform 1.505e-4;
    baseright
    sides
    back
        type            fixedValue;
    outlet
        type            zeroGradient;
|  \\    /   O peration     | Version:  2.1.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      k;
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 2.383e-3;
boundaryField
    baseleft
        type            compressible::kqRWallFunction;
        value           uniform 2.383e-3;
    baseright
    sides
    back
       type            fixedValue;
    outlet
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      p;
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //dimensions      [ 1 -1 -2 0 0 0 0 ];
internalField   uniform 101325;
boundaryField
    baseleft
        type            zeroGradient;
    baseright
        type            zeroGradient;
    sides
        type            zeroGradient;
    back
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 101325;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      p_rgh;
boundaryField
    baseleft
        type            zeroGradient;
    baseright
        type            zeroGradient;
    sides
        type            zeroGradient;
    back
        type            zeroGradient;
    outlet
        type            fixedValue;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      T;
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //dimensions      [0 0 0 1 0 0 0];
internalField   uniform 1373;
boundaryField
        type            fixedValue;
        value           uniform 1373;
    back
    type            fixedValue;
        value           uniform 1373;
    outlet
       type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
        type            fixedValue;
        value           uniform (0 0 0);
    back
        type            fixedValue;
        value           uniform (0 0 -1.5);
    outlet
        type            zeroGradient;
Does anyone have an idea what is wrong??
Many thanks in advance,
regards
Matze7 is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Temperature, Pressure Limited + numerical error Michael P Main CFD Forum 4 August 3, 2007 12:00
numerical stability due to cross derivatives wen long Main CFD Forum 2 September 12, 2005 02:10
Inlet Temperature Fluctuation in CFX-5.7 LES Mode Halim Choi CFX 0 December 23, 2004 22:05
Parabolic temperature Inlet Profile in a tube majestywzh FLUENT 0 April 9, 2003 06:37
