High local velocities in interDyMFoam
Old   May 23, 2013, 04:48
Default High local velocities in interDyMFoam
Anon
jrrygg is on a distinguished road
I have a simulation where a high speed jet of water (38.38 ms-1) interacts with a rotating turbine bucket in interDyMFoam. I have a problem with the courant number being very low (10-8), much because of an extremely high velocity (10⁵ ms-1) in a few cells around the bucket.
I wonder if anyone else has seen this behavior in interDyMFoam, and maybe knows how I can avoid velocities of this magnitude?
Kind regards,
Jone
jrrygg is offline   Reply With Quote
Old   June 28, 2013, 22:38
dawnrain is on a distinguished road
hi Jone
Maybe you can define another parameter in creatFields.H to replace Alpha1 for refinement. Like this
Add following lines in creatFields.H
Info<< "Creating field Laplacian U\n" << endl;
volScalarField laplaceU
IOobject
"laplaceU",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
(mag(fvc::laplacian(U.component(0)))
+ mag(fvc::laplacian(U.component(1)))
+ mag(fvc::laplacian(U.component(2))))
add following lines in interDyMFoam.C after pressure possion equation loop
// --- calculate laplacianU for refinement
laplaceU = (mag(fvc::laplacian(U.component(0)))
+ mag(fvc::laplacian(U.component(2))));
// --- calculate average laplacianU
dimensionedScalar laplaceUAver =
sum(laplaceU * mesh.V()) / sum(mesh.V());
// --- laplacianU
laplaceU = laplaceU / laplaceUAver;
Logicallly, the field laplaceU will be high on the interface and area with sharp velocity gradient.
Don't forget modify costant/dynamicMeshDict, like
change:
field alpha1;
lowerRefineLevel 0.001;
upperRefineLevel 0.999;
to:
field laplaceU;
lowerRefineLevel 4; //test
upperRefineLevel 1e10;
But i am not sure whether the change will be accepted by interDyMFoam, because adaptive mesh refinement code is difficult for me. Hope you succeed!
dawnrain is offline   Reply With Quote
interdymfoam
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 15:24
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
