March 5, 2013, 19:12 |
OpenFOAM virtual memory error
I am trying to run an internal pipe flow with obstruction simulation. I have succesfully created a mesh using snappyHexMesh and then I have been solving with simpleFoam. I am running openFOAM in ubuntu via virtualbox with a Windows 8 host. My solution was obviously incorrect and I could see that it was not converging after having plotted residuals; so I decided to increase the density of my background blockMesh mesh in the hope of solving this problem. My new mesh is built fine with approximately ~1.8M cells, but when I run simpleFoam it begins calculating, finishes the first time step and then quits with the following error: new cannot satisfy memory request. This does not necessarily mean you have run out of virtual memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library. Aborted. I gave my virtual machine 5G of RAM so I don't know what the problem is. Any help would be great, Thanks |
July 12, 2013, 07:24 |
Shashank Reddy
Rep Power: 12 |
Hi spoon,
Have you found your solution yet ? Does it have anything to do with the virtual memory I have encountered the same error. regards, |
error, openfoam, virtual memory |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
