Outlet pressure boundary condition in interFoam |
July 4, 2013, 18:25 |
Arnau
Rep Power: 14 |
I am running an interFoam case with inlet and outlet and I don't know how to define the pressure (p_rgh) boundary condition in the outlet. I tried to use the same as the patch "sky" in the damBreak tutorial, but I got a physical no-sense (see attached screenshot).
I also tried several solutions, such as that of this link and several of CFD-online, but my simulations either didn't run or diverged after a few iterations. I know it's some tiny detail I'm missing, but I don't know what to do. I also tried a "zeroGradient" type of boundary condition for pressure and "fixedValue" of zero, but it didn't work. Thank you very much! |
July 9, 2013, 11:27 |
Artur
Rep Power: 20 |
You didn't say exactly what your simulation is and the picture didn't help me much.
I use LTSInterFoam for ship hydrodynamic calculations and typically go for zeroGradient or fixedValue uniform 0 for the dynamic pressure term at the outlet. I suppose you could also use something like inletOutlet too. |
July 10, 2013, 04:19 |
Details on "Outlet pressure boundary condition in interFoam"
Arnau
Rep Power: 14 |
Hi Artur,
You're right, I gave very scarce information. I've attached a new picture with some more details on the pressure boundary conditions (henceforth B.C.) of my simulations. As regards the outlet, as you suggested, I've used a zeroGradient as well as a fixedValue uniform 0 and it didn't work. I also copied the B.C. settings of the "atmosphere" patch in damBreak (inletOutlet type in "boundary" and totalPressure for "p_rgh") and I always get the same result. However, I've recently observed that at higher inlet velocities, the jet leaves the domain though the right-hand outlet instead of through the bottom and everything works perfectly. I've also run the damBreak case changing one of the side walls to an outlet B.C. and this "spurious" bubbles didn't appear either. Is it possible that this problem only arises when the outlet is horizontal (i.e. perpendicular to the gravity direction)? Maybe it's due to the use of "p_rgh" (gravity corrected pressure) instead of "p". Thank you very much for your help. Regards, Arnau. |
July 10, 2013, 04:30 |
Artur
Rep Power: 20 |
Ok, I see what you mean now. Unfortunately I don't know much about gravity driven flow simulations as I use interFoam only to calculate the free surface of moving ships so hopefully someone more experienced will have a look at your post. In the meantime, your mesh seems fairly coarse in the outlet region, have you tried refining it a bit to see if it makes a difference?
P.S. I don't think that the horizontal orientation of the outlet should make any difference because it seems like it should be (by enlarge) perpendicular to the flow of the jet. |
July 10, 2013, 04:43 |
Pablo Higuera
Rep Power: 19 |
Hi Arnau,
I think the problem may be caused by the bottom outlet, as I guess it is located below Z = 0 plane. Try making all your outlet patchs be located in the first quadrant (x,y,z>0) and use the same BCs as for the atmosphere and let us know if it gets better. Best, Pablo |
July 10, 2013, 08:26 |
Arnau
Rep Power: 14 |
@Artur:
Maybe you're right about the mesh, I haven't had the time to try more refined meshes (I'm running some simulations as I write). However, the damBreak case run perfectly with a coarser mesh and with an outlet instead of one of the side walls, as I described in my previous post. @Pablo: You're right, the outlet was below the Z=0 plane. Indeed, in previous simulations I've observed that everything started going bad when the jet crossed this plane (that sounds kind of esoteric, doesn't it?). Nevertheless, I've run the same simulation as you said: in the first quadrant and with the same BC as the atmosphere but I still get the same result (I've attached a video). I'm trying finer meshes to see what happens, I'll let you know about the results. Video: https://www.dropbox.com/s/corgjwhem1...let_as_sky.avi BTW, these are the dictionaries of my outlet patch: Code:
// boundary outlet { type wall; } // U outlet { type pressureInletOutletVelocity; value uniform (0 0 0); } // alpha1, k, epsilon outlet { type inletOutlet; inletValue $internalField; value $internalField; } // p_rgh outlet { type totalPressure; p0 uniform 0; U U; phi phi; rho rho; psi none; gamma 1; value uniform 0; } Best, Arnau. |
July 10, 2013, 08:37 |
Artur
Rep Power: 20 |
I noticed you defined the outlet as a wall in your boundary file. Maybe try changing it to patch? On the video it appears as if the flow is not passing through the outlet so perhaps this is the reason.
July 10, 2013, 08:48 |
Pablo Higuera
Rep Power: 19 |
try this: Code:
// alpha1 outlet { type inletOutlet; inletValue 0; value $internalField; } |
July 10, 2013, 10:28 |
#9 |
Arnau
Rep Power: 14 |
@Artur:
I used "wall" as B.C. because is the type to which the patch "atmosphere" belongs. I also tried the generic "patch" and I got the same result. @Pablo: Since my alpha1 "internalField" is assigned "uniform 0", what you suggest is what I have been trying. Any idea? This is exhausting... I'll let you know what happens with the finer-mesh simulations. Best, Arnau. |
July 11, 2013, 03:16 |
#10 |
Arnau
Rep Power: 14 |
Here are the results with a finer mesh and the problem persists:
https://www.dropbox.com/s/t8ekfxdm20...resolution.avi I've zipped the entire simulated case (before running), in case somebody wanted to check it out: https://www.dropbox.com/s/fnc8nuu1iwp4h5e/dam.zip I don't know what else I should try... |
July 11, 2013, 03:28 |
#11 |
Pablo Higuera
Rep Power: 19 |
Well, actually in this case you provided the bottom outlet is actually included in patch "wall" instead of being part of "outlet"...
July 11, 2013, 03:46 |
#12 |
Arnau
Rep Power: 14 |
Yes, Pablo, this is the last case I run, but as I told you I tried with "patch" as well. Anyway, the patch "atmosphere" in damBreak is defined as "wall", that's why this was my first option.
July 11, 2013, 03:54 |
#13 |
Pablo Higuera
Rep Power: 19 |
What I mean is that the bottom portion you intend to use as an outlet is actually a part of the boundary called "wall" instead of the one called "outlet" (disregarding if they are either a patch or a wall type), so the boundary conditions of "wall" apply instead of the boundary conditions of "outlet". See the attached picture ("wall" in red and "outlet" in blue)
July 11, 2013, 03:57 |
Random question
#14 |
Bryan
Rep Power: 12 |
Hi, I'm new to this forum. I'm trying to create a new post but I can't find the "New Post" or "New Thread" button. Help?
July 11, 2013, 04:02 |
#15 |
Arnau
Rep Power: 14 |
Yes, since I thought the horizontal outlet may have been the cause of my troubles, I tried to define as outlet only the vertical patches (again, I tried both cases, but the one I uploaded was the last one). Anyway, the result is the same: the water keeps on blocking at the outlet.
Thanks for your time, Pablo! |
#16 | |
Artur
Rep Power: 20 |
http://www.cfd-online.com/Forums/openfoam/ |
July 11, 2013, 04:05 |
#17 | |
Bryan
Rep Power: 12 |
July 11, 2013, 04:12 |
#18 | |
Artur
Rep Power: 20 |
http://www.cfd-online.com/Forums/ope...letoutlet.html I thought that maybe if your outflow is not strong enough it will not actually leave the domain? This would tie in with what you said earlier that with increased inlet velocity the problem disappears. Just a thought... |
November 26, 2013, 08:57 |
BC located at z=0 => rho*g*h = 0
#19 |
Thibault Pringuey
Rep Power: 17 |
Hello Arnau,
I am sort of looking at the similar issues. As you suggested, I believe that the issue related to the setting of a static pressure BC with p_rgh. Have you tried setting your outlet BC to z=0 such that by setting fixed value of p_rgh = p_outlet_static + rho*g*0 = p_outlet_static? Anyway, have you solved your problem? Regards, Thibault |
November 26, 2013, 10:00 |
#20 |
Arnau
Rep Power: 14 |
Hi Thibault,
I solved the problem to a certain extent. What I did is the following: I realized that supercritical flow outlets in OpenFOAM behave as expected as long as there is no flow separation (I got the idea from this tutorial). So I replaced the spill of my model with a descending slope (see attached picture), set all the variables at the outlet to zeroGradient (except for pressure, which I set to buoyantPressure) and everything ran smoothly. I am still trying to do all this in a more elegant way without spills, slopes and so on: just directly imposing a given water depth and a hydrostatic pressure profile at the outlet. I will try to keep you informed of my findings. Good luck! Arnau. |
interfoam outlet p_rgh |
Outlet boundary condition for wave flume with interFoam solver | Arnoldinho | OpenFOAM | 9 | July 10, 2018 05:15 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
Turbulent intensity for pressure Outlet Boundary condition | Mohsin | FLUENT | 1 | April 30, 2010 10:36 |
