OpenChannel with Two Cylinders in icoFoam
Old   July 6, 2013, 06:36
Default OpenChannel with Two Cylinders in icoFoam
Zhengbing
jimbean is on a distinguished road
I am trying to set up a case, like cavity, in icoFoam folder.
The case is to simulate 3D water flow around two tandem cylinders in open channel.
The mesh is generated with Gridgen (see attached figure, top view), hexahedral.
The left is inlet boundary and right is outlet boundary. The surface give symmetry boundary and the side and bottom wall are wall boundary.
velocity-inlet-4
type patch;
nFaces 56;
startFace 16992;
wall-5
type wall;
nFaces 4120;
startFace 17048;
symmetry-6
type symmetryPlane;
inGroups 1(symmetryPlane);
nFaces 3528;
startFace 21168;
outflow-8
type patch;
nFaces 56;
startFace 24696;
Initial boundary: P
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
velocity-inlet-4
type zeroGradient;
wall-5
type zeroGradient;
outflow-8
type fixedValue;
value uniform 0;
symmetry-6
type symmetryPlane;
U
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
velocity-inlet-4
type fixedValue;
value uniform (0.1 0 0);
outflow-8
type zeroGradient;
symmetry-6
type symmetryPlane;
wall-5
type fixedValue;
value uniform (0 0 0);
I also changed the deltaT to make sure the Courant number is less than 1.
For the fvschemes and fvsolution i didn't change them.
With these modifies, i run the checkMesh. The mesh is ok.
And the icoFoma,
The Courant number increases too high and make the calculation break down.
Could anyone help me out?
Best
jimbean is offline   Reply With Quote
Old   July 6, 2013, 10:34
Nima Samkhaniani
nimasam is on a distinguished road
Hello
maybe assign an appropriate initial condition help for numerical convergence,
i suggest to use for example:
for U:
internalField uniform (0.1 0 0);
also post your error log file, it may help OpenFOAM users to help you
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   July 6, 2013, 10:50
Zhengbing
Hi Nima,
I tried to change the initial condition you suggested, but it still has the same problem.
Now I post the error message
Courant Number mean: 4.27005e+101 max: 1.43938e+104
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
at ??:?
at ??:?
at ??:?
at ??:?
at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
at ??:?
Floating point exception (core dumped)
Originally Posted by nimasam View Post
Hello
for U:
Old   July 6, 2013, 12:33
Nima Samkhaniani
use a very small time step for example 1e-6 or 1e-08
Old   July 6, 2013, 14:47
subhendu
subhsngh is on a distinguished road
no it does not work i am having the same problem
subhsngh is offline   Reply With Quote
Old   July 6, 2013, 15:09
Nima Samkhaniani
post your case here
Old   July 6, 2013, 17:01
subhendu
Time = 0.000145
Courant Number mean: 1.41367e+82 max: 1.17207e+86
DILUPBiCG: Solving for Ux, Initial residual = 0.999949, Final residual = 5.82071, No Iterations 1001
DILUPBiCG: Solving for Uy, Initial residual = 0.999934, Final residual = 6.42952, No Iterations 1001
DILUPBiCG: Solving for Uz, Initial residual = 0.999958, Final residual = 4.32912, No Iterations 1001
DICPCG: Solving for p, Initial residual = 1, Final residual = 23.5112, No Iterations 1001
time step continuity errors : sum local = 1.55446e+90, global = 1.20778e+75, cumulative = 1.20778e+75
DICPCG: Solving for p, Initial residual = 0.946822, Final residual = 8.63811, No Iterations 1001
time step continuity errors : sum local = 2.01094e+92, global = -3.33867e+76, cumulative = -3.2179e+76
ExecutionTime = 1546.13 s ClockTime = 1553 s
Time = 0.00015
Courant Number mean: 3.61103e+92 max: 4.64632e+96
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/icoFoam"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
my delta t was 0.000005 u was 0.0001
Old   July 7, 2013, 02:25
Nima Samkhaniani
Dear
your solution does not converge in each iteration, look that after 1001 iteration your residual is uprising, i said post your whole case not just a few last error log
Old   July 7, 2013, 02:33
subhendu
which files do u want
Old   July 7, 2013, 02:39
Nima Samkhaniani
post the contents of 0, constant and system the whole case :P, then i can try it by my own
Old   July 7, 2013, 02:47
subhendu
case icoFoam
directory 0
file p
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
boundaryField
movingWall
type zeroGradient;
fixedWalls
type zeroGradient;
frontAndBack
type zeroGradient;
Old   July 7, 2013, 02:49
subhendu
directory 0
file u
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
boundaryField
movingWall
type fixedValue;
value uniform (0 0 1);
fixedWalls
type fixedValue;
frontAndBack
type fixedValue;
Old   July 7, 2013, 02:52
subhendu
transportProperties
nu nu [ 0 2 -1 0 0 0 0 ] 0.01;
Old   July 7, 2013, 02:55
subhendu
boundary
3
movingWall
type patch;
nFaces 10;
startFace 252345;
fixedWalls
type patch;
nFaces 10;
startFace 252355;
frontAndBack
type patch;
nFaces 25198;
startFace 252365;
Old   July 7, 2013, 03:27
Default case
  #15
subhendu
i have created a cylicrical mesh with inlet and outlet of radius 100 and diam,eter of 1000
Old   July 7, 2013, 07:55
Zhengbing
Hi Nimasam,
I have attached constant folders.
Since the size of constant folds exceed the limitation, i split it into four.
Due to the upload file type, i add .tar.gz suffix to each split file, so first please delete the suffix .tar.gz and then
Using
cat constant* > constant.tar.gz
to recover the constant files.
post your case here
Old   July 7, 2013, 07:57
Zhengbing
Here is the 0 and system folders.
post your case here
Old   July 7, 2013, 07:59
Nima Samkhaniani
you could create a zip file, and you could upload it!, if its size was more than site allowed upload size, you could use dropbox or 4shared to upload your case
also it would be helpful for you to read this post, it shows you how to post in forum to receive much more help
Old   July 7, 2013, 08:37
Zhengbing
Hi Nimasam,
Thanks for the suggestion.
Could you help me check this case?
I attached the link,
https://www.dropbox.com/s/5m2vw11e6a...ylinder.tar.gz
Old   July 7, 2013, 09:10
subhendu
i am posting my case
2D Aerofoil with rotating cylinders - Help & Advice! Bluejay OpenFOAM 1 December 31, 2012 04:40
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
[ICEM] generating tetra mesh on various cylinders at the same time karananand ANSYS Meshing & Geometry 2 July 9, 2010 16:34
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
