resolution
Like Tree1Likes
  • 1 Post By mturcios777
Old   July 17, 2013, 14:40
Default resolution
izna O'connor
izna is on a distinguished road
hi..
How can i know which resolution i am running my case?
example for a hill , i mesh it and then run it with the solver.
So how do i know the resolution?
Thanks
izna
izna is offline   Reply With Quote
Old   July 17, 2013, 16:57
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Originally Posted by izna View Post
hi..
Thanks
izna
If you mean mesh resolution, that is controlled by you in the meshing stage. If you did it with blockmesh, you control the resolution of each block. If you used snappyHexMesh, then resolution depends on the refinement criteria for each surface. You can use checkMesh to give you overall cell numbes and min/max cell volume, which may help you in with determining resolution.
mturcios777 is offline   Reply With Quote
Old   July 17, 2013, 17:02
izna O'connor
hi..
how can I control my mesh? i am a bit confused here.
Old   July 17, 2013, 17:03
Marco A. Turcios
What program did you use to create you mesh?
Old   July 17, 2013, 17:06
izna O'connor
i obtained my mesh from snappy and block..
But i have downloaded a case file from the net with .stl file.. there already i think the case was created
Old   July 17, 2013, 17:10
Marco A. Turcios
If you haven't already done so, read the manual sections on meshing:
http://www.openfoam.org/docs/user/mesh.php#x22-1270005
The blockMeshDict gives you the base mesh density, and in snappyHexMeshDict you will find out how to set the refinement levels for the STL surfaces. It will make more sense once you read the manuals carefully.
izna likes this.
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
[OpenFOAM] vorticity resolution in paraFoam ebah6 ParaView 11 December 11, 2017 16:03
Numerical Weather Modelling : Time and space resolution issues chriswatt Main CFD Forum 0 February 15, 2011 21:32
Large difference in grid resolution for diff paper Ben Main CFD Forum 16 April 7, 2007 11:45
plot open gl color resolution to file michael Siemens 1 October 22, 2003 14:43
