How to get cell face temperature??
Like Tree1Likes
  • 1 Post By ARTem
Old   July 19, 2013, 14:57
Default How to get cell face temperature??
George Pichurov
jorkolino is on a distinguished road
I need the boundary cell face temperature to use in an expression. How can I access it in the code ? For example, I can define boundary field like:
        const surfaceScalarField::GeometricBoundaryField& patchHeatFlux =
            heatFlux.boundaryField();
(where heatFlux is a SurfaceScalarField entity). However, expression like T.boundaryField() ( instead of heatFlux.boundaryField() )produces an error. Why the temperature cannot have a boundary field defined like that?
Ed. I am maybe heading into some sort of a solution, but I have a question. Why is the h field (probably enthalpy) recognized when adressed in the code, and T field is not? The brutal example is I can interpolate fvc::interpolate(h) and take gradient fvc::snGrad(h), but non of these with T. I am customizing the wallHeatFlux utility, by the way.
jorkolino is offline   Reply With Quote
Old   July 22, 2013, 04:24
Artem Shaklein
ARTem is on a distinguished road
Hello, jorkolino.
Any field type has boundaryField (bF). But as far as I know, there are different types of bF (e.g. surfaceScalarField.bF() and volScalarField.bF() are not same even on same mesh). i don't know the details of that inconsistency, but this should do the job:
const volScalarField::GeometricBoundaryField& Tpatch =T.boundaryField();
The most robust choise is to use cycle (e.g. you want to make some algebraical operations with boundaryFields of vol (vf) and surfaceFields(sf)).
forAll(sf.boundaryField(), patchi)
  forAll(sf.boundaryField()[patchi], facei)
    sf.boundaryField()[patchi][facei] += fv.boundaryField()[patchi][facei];
But be accurate with dimensions, because type of sf.boundaryField()[patchi][facei] is scalar (or double in c++) and dimensions checking isn't done here.
codder likes this.
ARTem is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
How to determine the direction of cell face vectors on processor patches sebastian_vogl OpenFOAM Running, Solving & CFD 0 October 27, 2009 08:47
how to access each cell of a face? (user fortran) Katariina CFX 3 January 28, 2008 09:16
