Averaging a field in parallel during the simulation
Old   July 23, 2013, 11:07
Default Averaging a field in parallel during the simulation
Saba Saeb
saba_saeb is on a distinguished road
I need to take the average of a field on a boundary during the simulation. I am doing that using the normal approach:
scalar tmp= average(frictionvelocity);
where frictionvelocity is a scalar field. Everything is running like a charm in serial, but the simulation would stop if I run it in parallel. I tried to tackle the problem using this approach:
scalar tmp= average(frictionVelocity);
scalar tauw = returnReduce(tmp, sumOp<scalar>());
But the output is not correct since the calculated averages on every processors are being added together which make tauw that seems incorrect. Any idea would be appreciated.
Tnx,
Saba
saba_saeb is offline   Reply With Quote
Old   July 23, 2013, 11:31
akidess's Avatar
Anton Kidess
Something along these lines might work:
int numprocs;
MPI_Comm_size(MPI_COMM_WORLD, &numprocs);
tauw /= numprocs;
Info<< tauw << endl;
Ninja edit - this is better:
label numprocs=Pstream::nProcs();
tauw /= numprocs;
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   July 23, 2013, 11:39
Saba Saeb
int numprocs;
tauw /= numprocs;
tauw /= numprocs;
Hi Anton,
Tnx for your reply.
That was the first idea that came to my mind, not however division by the total number of processors, but, division by no. of processors in x direction time no. of processors in z direction since friction velocity is just being calculated on the boundary located at the bottom of a channel, in my case. However, this is not still giving me the expected results since friction velocity is not being spread uniformly along the wall!
If anything seems unclear to me, please let me know.
Cheers,
Saba
Old   July 23, 2013, 11:40
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
There is gAverage function.
Explanation and examples can be found for example at - http://www.cfd-online.com/Forums/ope...tml#post202817.
alexeym is offline   Reply With Quote
Old   July 23, 2013, 12:13
Saba Saeb
Hi Alexey,
gAverage is apparently solving the problem. Tnx for your hint.
Cheers,
Saba
constant variables in all processors , parallel simulation saba_saeb OpenFOAM Programming & Development 0 July 17, 2013 13:07
help with command line in parallel simulation ernest STAR-CCM+ 8 August 17, 2011 05:02
A parallel simulation problem in DPM satum FLUENT 0 October 21, 2008 05:38
How to run parallel simulation on PC with two-CPU? Jimmy FLUENT 1 July 14, 2008 00:46
How to run a parallel simulation? J.Gimbun FLUENT 9 May 24, 2006 05:47
