Porous media model in OpenFOAM 14
Old   July 2, 2007, 02:47
Default The release notes for v. 1.4 r
gac
gac
gac is on a distinguished road
The release notes for v. 1.4 refer to a "Porous media model including power-law inertial and viscous models for either explicit or implicit implementation in any of the pressure-velocity solvers (demonstration example included)."
However, there is no mention of the porous media model in the User Guide, and I can't find the "demonstration example."
Any assistance is appreciated.
gac is offline   Reply With Quote
Old   July 2, 2007, 03:46
Default In the tutorials directory, yo
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
In the tutorials directory, you should find both
rhoExplicitPorousSimpleFoam and rhoImplicitPorousSimpleFoam with an angleDuct example.
For higher flow resistances, the implicit formulation should be more robust. I don't think that it costs much more either.
olesen is offline   Reply With Quote
Old   July 2, 2007, 05:12
Default You can find class files in:
Masato Otsuki
otsuki is on a distinguished road
OpenFOAM-1.4/src/finiteVolume/cfdTools/general/porousMedia
You can find brief comments in "porousZones.H".
otsuki is offline   Reply With Quote
Old   July 4, 2007, 08:03
Default Hi When I try to run the a
abhishek k n
knabhishek is on a distinguished road
Hi
When I try to run the angleDuct tutorial the following error is reported.
FoamXError "getApplication::Invalid application class name 'rhoExplicitPorousSimpleFoam'."
In function "IPropertiesImpl"
in file "IPropertiesImpl.C" at line 910
knabhishek is offline   Reply With Quote
Old   July 4, 2007, 09:13
Default Do you get it to work without
Mark Olesen
Do you get it to work without FoamX?
Old   July 4, 2007, 09:41
Default No I can't get it to run witho
abhishek k n
No I can't get it to run without FoamX: in fact I don't know how to create a case from the terminal using solvers that don't have a tutorial associated with them (like dieselEngineFoam). I have so far been using the drop down menu in FoamX having only access to the default solvers upon creating a case. Maybe knowing how to do this will solve my problem.
When i run the case angleDuct on terminal I am using this command:
rhoPorousSimpleFoam ~/ angledDuctImplicit
the following error is reported:
FOAM FATAL ERROR : Cannot find file "points" in directory "constant/polyMesh"
From function Time::findInstance(const word& dir, const word& name) in file db/Time/findInstance.C at line 133.
I have aslo noticed there is no solver with name rhoImplicitPorousSimpleFoam and rhoExplicitPorousSimpleFoam
But there is a rhoPorousSimpleFoam. Maybe I need to use rhoExplicitPorousSimpleFoam in conjunction with something??
Old   July 4, 2007, 10:35
Default The points are missing because
Assistant Moderator
Bernhard Gschaider
The points are missing because you didn't run blockMesh yet
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 1, 2007, 14:24
Default Hi, i've just downloaded and
stchouan
i've just downloaded and installed the last version of OpenFoam and i was wondering if anybody had any experience with it on solving coupled and non linear convection-diffusion problems like those in reservoir or bassin simulation in the oil industry. Particularly with heterogenous and anisotropic porous media, has anyone ever used OpenFoam to simulate compressible two-phase flows in porous media?
Thanks for your answers.
Old   August 1, 2007, 17:34
Default Hi Stephane, Compressible t
Eugene de Villiers
eugene is on a distinguished road
Hi Stephane,
Compressible two-phase flow has been done for transonic sprays, but I am not aware of any two-phase flow calculations in conjunction with porous media. To get it working would require some coding and depending on your working fluids, the possible implementation of additional equations of state. You can mail me directly if you require additional info.
eugene is offline   Reply With Quote
Old   September 12, 2007, 07:35
Default Hi When I try to run the an
Paul Mauk
plmauk is on a distinguished road
Hi
When I try to run the angleDuct tutorial the following error is reported:
I know, the same question was asked by "abhishek kn"
but I couldnt find any answer...
plmauk is offline   Reply With Quote
Old   September 12, 2007, 08:23
Default I've tried to run this case wi
  #11
Paul Mauk
I've tried to run this case without FoamX,
but it did not work. I've got following message:
FOAM FATAL IO ERROR : keyword pressureImplicitPorousity is undefined in dictionary "/home/cfduser1/OpenFOAM/cfduser1-1.4.1/run/tutorials/rhoExplicitPorousSimpleFoa m/angledDuctExplicit/system/fvSolution::SIMPLE"
file: /home/cfduser1/OpenFOAM/cfduser1-1.4.1/run/tutorials/rhoExplicitPorousSimpleFoam /angledDuctExplicit/system/fvSolution::SIMPLE from line 75 to line 76.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 146.
Old   September 12, 2007, 21:35
Default Hi Paul, The swich pressure
  #12
Masato Otsuki
Hi Paul,
The swich pressureImplicitPorousity has no effect
for rhoExplicitPorousSimpleFoam.
Modify angledDuctExplicit/system/fvSolution as:
SIMPLE
nNonOrthogonalCoccectors 0;
pMin pMin [1 -1 -2 0 0 0 0] 100;
pressureImplicitPorousity No;
and try again.
Masato
Old   September 13, 2007, 08:22
Default Hi, Masato! It seems to work.
  #13
Paul Mauk
Hi, Masato!
It seems to work.
Thank you very mutch!
Old   October 30, 2007, 06:01
Default Hi, everyone! The case don't
  #14
Paul Mauk
Hi, everyone!
The case don't work once again.
FOAM exiting
Can anybody help me please?
Old   October 30, 2007, 06:55
Default To Paul Mauk: you should run b
  #15
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
To Paul Mauk: you should run blockMesh before running case
mkraposhin is offline   Reply With Quote
Old   October 31, 2007, 06:19
Default To Matvej Karposhin: Thank you
  #16
Paul Mauk
To Matvej Karposhin: Thank you very match for helping. Would you like to share some experience in Open Foam with me? In russian?
Old   October 31, 2007, 06:48
Default Paul Mauk, ii would be nice, i
  #17
mkraposhin's Avatar
Matvey Kraposhin
Paul Mauk, ii would be nice, if you can speak russian language (english is still very difficult to me).
What kind of problems are you intersted in OpenFoam?
Old   October 31, 2007, 07:07
Default Of course, I can speak russian
  #18
Paul Mauk
Of course, I can speak russian much better than english. I think it would be better, you tell me your e-mail adress and I will write an e-mail, to discribe my problems.
Old   November 1, 2007, 05:57
Default Paul Mauk, here is my e-mail:
  #19
mkraposhin's Avatar
Matvey Kraposhin
Paul Mauk, here is my e-mail: mkraposhin@inbox.ru, same as in profile.
Old   September 7, 2009, 04:29
Default LHS and RHS of + have different dimensions
  #20
srikara's Avatar
Srikara Mahishi
srikara is on a distinguished road
I am running the rhoPorousSimpleFoam solver to solve a porous media simulation in OF 1.5. I get the following error message when I enter the command:
Starting time loop
Time = 0.1
dimensions : [0 2 -1 0 0 0 0] + [1 -1 -1 0 0 0 0]
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/smahishi/OpenFOAM/OpenFOAM
-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/smahishi/OpenFOAM/OpenFOAM-1.5/lib/linux64Gcc
#2 Foam:perator+(Foam::dimensionSet const&, Foam::dimensionSet const&) in "/h
ome/smahishi/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#3 Foam::tmp<Foam::GeometricField<Foam::typeOfSum<dou ble, double>::type, Foam::
fvPatchField, Foam::volMesh> > Foam:perator+<double, double, Foam::fvPatchFiel
d, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foa m::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::vol Mesh> const&) in "/home/smahishi/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libco mpressibleRASModels.so"
#4 Foam::compressible::RASModel::muEff() const in "/home/smahishi/OpenFOAM/Open FOAM-1.5/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#5 Foam::compressible::RASModels::kEpsilon::divDevRho Reff(Foam::GeometricField< Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/home/smahi shi/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#6 main in "/home/smahishi/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPO pt/rhoPorousSimpleFoam"
#7 __libc_start_main in "/lib64/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/home/smahishi/OpenFOAM/OpenFOAM-1.5 /applications/bin/linux64GccDPOpt/rhoPorousSimpleFoam"
From function operator+(const dimensionSet& ds1, const dimensionSet& ds2)
in file dimensionSet/dimensionSet.C at line 403.
FOAM aborting
Aborted
Does anybody know where this addition is taking place? It has something to do with muEff, that much I understand. Could anybody please let me know what I need to modify here?
Thank you in advance,
Srikara
srikara is offline   Reply With Quote
CFX: what is "A true volume-porous media model?" whiz CFX 28 April 16, 2019 08:14
Porous media in openfoam arturo OpenFOAM Running, Solving & CFD 31 March 16, 2013 16:07
Power law model for porous media Karl FLUENT 0 December 13, 2004 15:14
turbulence model in porous media zhzhguo FLUENT 2 November 1, 2004 07:10
Question about porous media model Glenn Price FLUENT 5 June 28, 2000 11:48
