Unexpected step-to-step divergence?
Old   September 5, 2013, 10:26
Default Unexpected step-to-step divergence?
Petr Furmanek
petr.f. is on a distinguished road
Hi all,
I'm facing problem with unexpected, step-to-step divergence when carrying out two-phase flow simulations in a straight tube (mixture of very small gas bubbles in liquid) . The settings are as follows:
- application: interFoam
- adjustableRunTime
- parallel computation on 128 cores (sandybridge)
- polyhedral mesh (~2.6e6 cells)
- k-w SST turbulence model (with wall functions ;-| )
- gradSchemes: cellLimited pointCellsLeastSquares 1
- divSchemes: Gauss linearUpwind pointCellsLeastSquares for fluxesm vanLeer01 for alpha, upwind for k and w
- laplacianSchemes: Gauss harmonic limited 0.5
- p_rgh solver PCG preconditioned by GAMG
- U solver: coupled GaussSeidel
- k-w solver: DILUGaussSeidel
- relaxation for U 0.8, p_rgh 0.8, k and omega 0.5
The computation starts and runs without any significant problems, but then just out of nowhere something like this happens:
Courant Number mean: 0.0580293 max: 3.24124
Interface Courant Number mean: 0.0306811 max: 1.19673
deltaT = 4.30429e-06
Time = 0.387167774895511296318062477439525537192821502685 546875
MULES: Solving for alpha1
Phase-1 volume fraction = 0.843784 Min(alpha1) = 0 Max(alpha1) = 1
Phase-1 volume fraction = 0.843785 Min(alpha1) = 0 Max(alpha1) = 1
Phase-1 volume fraction = 0.843786 Min(alpha1) = 0 Max(alpha1) = 1
Phase-1 volume fraction = 0.843787 Min(alpha1) = 0 Max(alpha1) = 1
PIMPLE: iteration 1
GAMGPCG: Solving for p_rgh, Initial residual = 0.0224785, Final residual = 0.000156967, No Iterations 1
time step continuity errors : sum local = 1.55616e-07, global = 5.43803e-09, cumulative = 0.000297041
GAMGPCG: Solving for p_rgh, Initial residual = 0.00199818, Final residual = 4.15425e-05, No Iterations 1
time step continuity errors : sum local = 4.24289e-08, global = 3.81493e-09, cumulative = 0.000297045
PIMPLE: iteration 2
GAMGPCG: Solving for p_rgh, Initial residual = 0.00614802, Final residual = 9.2905e-05, No Iterations 1
time step continuity errors : sum local = 9.60018e-08, global = -7.49441e-08, cumulative = 0.00029697
GAMGPCG: Solving for p_rgh, Initial residual = 0.14632, Final residual = 0.00109295, No Iterations 1
time step continuity errors : sum local = 1.32961e-06, global = 7.27154e-07, cumulative = 0.000297697
PIMPLE: iteration 3
GAMGPCG: Solving for p_rgh, Initial residual = 0.990129, Final residual = 0.00744816, No Iterations 1
time step continuity errors : sum local = 0.00112567, global = 0.000659507, cumulative = 0.000957204
GAMGPCG: Solving for p_rgh, Initial residual = 0.999995, Final residual = 6.0151e-08, No Iterations 11
time step continuity errors : sum local = 0.00711768, global = 0.000152863, cumulative = 0.00111007
smoothSolver: Solving for omega, Initial residual = 1, Final residual = 9.87567e-10, No Iterations 29
smoothSolver: Solving for k, Initial residual = 0.863997, Final residual = 9.83797e-10, No Iterations 56
ExecutionTime = 128590 s ClockTime = 128985 s
Courant Number mean: 188929 max: 7.37508e+12
Interface Courant Number mean: 174035 max: 7.37508e+12
deltaT = 1.75088e-18
THE END
"High" value of the Courant number (3.24124 and 1.19673 for the interface Co) is tweaked by even higher number of nAlphaSubcycles and it limited by 5 (and 3 for interface Co). It works many times during the simulation so I don't think this is the main problem...
If I restart it, it just goes on (and it might or might not diverge in the same way). I can overcome this problem by modifying the interFoam so that it remembers the results from the last iteration, reloads it in the case of divergence and assure the smooth run by lowering the new deltaT. But this solution is kind of lame...
Have you experienced similar behaviour? Do you have any ideas how to solve it?
petr.f. is offline   Reply With Quote
Old   September 6, 2013, 01:49
Bernhard
Bernhard is on a distinguished road
In my experience, your best odds in resolving these kind of issues is reducing the maxCo and maxAlphaCo. What are these in your case?
Bernhard is offline   Reply With Quote
Old   September 6, 2013, 03:51
Petr Furmanek
As I wrote - maxCo = 5, maxAlphaCo = 3,
I'm tweaking it by the following settings for correctors:
nCorrectors 2;
nOuterCorrectors 3;
nNonOrthogonalCorrectors 0;
nAlphaCorr 1;
nAlphaSubCycles 4;
cAlpha 1;
I usually works, but sometimes, it suddenly blows up...
Old   September 6, 2013, 03:58
Bernhard
I was not sure if you were talking about the maxCo, or alphaSubCycles, but these Courant numbers are in general to large for interFoam, if you reduces them by an order, you won't face these problems.
There is by the way a lot of information on this forum related to time step size and interFoam.
Old   September 6, 2013, 04:02
Petr Furmanek
OK, thanks, I'll search for it...
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 22:24
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
