simpleFoam error with output sigFpe::sigHandler
Old   October 11, 2021, 03:19
Default simpleFoam error with output sigFpe::sigHandler
Muhammad Ahyar
Ahyar is on a distinguished road
i tried to run the simpleFoam on my case which based on windaroundbuildings tutorial case. but when i execute the simpleFoam command, it turns out the error like this one. how to solve this error? Thanks in advance
Ahyar is offline   Reply With Quote
Old   October 12, 2021, 16:32
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I am guessing here, but probably a divide by zero is found when reading the turbulence model. That probably means you have epsilon set as zero on a boundary or the internal field.
If you make this a positive value then you should be able to get further.
Cheers,
Tom
tomf is offline   Reply With Quote
What variable should I output to get wall force? Pauli CFX 6 May 15, 2018 07:58
How to control output time of pressureTools functions? Fluido OpenFOAM Post-Processing 1 May 19, 2014 08:49
CGNS Output file parameters ant0wn SU2 1 August 19, 2013 14:47
Questions about data output aki_yafuji OpenFOAM Running, Solving & CFD 3 September 9, 2010 01:59
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 12:30
