September 22, 2013, 17:38 |
Modelling Heat Transfer of a Lamp
I've created a lampshade suitable for 3D printing and I would like to determine the maximum wattage incandescent bulb which will not surpass the material's safe operating temperature. (I've also modelling the entire lamp)
I've read the first two chapters of the openFOAM user guide, and I feel pretty confident about converting the blender model to graded cells and specifying boundaries, however I'm not sure which model/solver I should use. I could use some help with the "big picture" approach. These are the specifics I would like to model:
September 23, 2013, 15:59 |
#2 | |
Jace
Rep Power: 15 |
I believe it handles turbulent flows, check out the tutorial case in foam's chtMultiRegionFoam directory for detail of case setup. Hope that helps! |
bulb, heat flow, heat transfer, light, thermal |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Heat transfer from a heated plate using fins | pathakamit | FLUENT | 1 | April 30, 2013 04:07 |
Modelling Heat transfer between stack and gas in Thermoacoustic | Chirag2302 | FLUENT | 0 | April 24, 2012 01:14 |
heat transfer modelling | morteza08 | Main CFD Forum | 2 | October 15, 2010 13:45 |
Modelling combustion and heat transfer | Tudor | FLUENT | 4 | May 9, 2005 07:02 |
