interFoam, setting velocity in fluid1 to zero
Old   January 19, 2015, 11:36
Default interFoam, setting velocity in fluid1 to zero
Martin K
Martin_K_lalelu is on a distinguished road
Hi!
To compare my VOF results of a deforming water droplet with a rigid droplet, I would like to keep using interfoam. Is there a way to set the velocity of one phase to zero, like in
forAll(mesh.cells(),celli)
    if(alpha1[celli]>0.0)
         U[celli]==vector::zero;
Unfortunately, this does not work, neither does an artificially high viscosity to simulate a rigid body.
There is a high chance that this is my fault, so any help would be really appreciated!
Martin_K_lalelu is offline   Reply With Quote
Old   March 5, 2015, 05:17
Thomas Vossel
ThomasV is on a distinguished road
Hi!
I'm having a similar problem: I added a temperature field to the solver and want to change the viscosity of the "water" phase depending on the temperature in each cell. I thus need access to the viscosity field...
What I figured out until now is this:
"twoPhaseProperties.nu()" returns the final viscosity field for each cell...
I didn't manage to get access to the initial viscosity fields though. All of this "unfortunately" is embedded in the incompressibleTwoPhaseMixture model. I really don't know much of this entire system that's being used for handling the phases so is there a way to get access to the respecitve fields and change them for each cell? Or with that said do functions which give access to those fields exist? I think the fields were created as protected objects inside the respective class so I won't be able to simply edit them in my solver routine...
It would be nice if someone who's a bit more familiar with this phase model could help us out here...
ThomasV is offline   Reply With Quote
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
A Question About Setting Whole Velocity Field Using "Proflie" in FLUENT adsl17754 FLUENT 5 July 31, 2018 04:29
Setting velocity at outlet saba_saeb FLUENT 29 December 12, 2012 05:16
Using UDF for setting velocity for two fluids UDF user FLUENT 7 November 26, 2008 07:22
