interPhaseChangeFoam and MRF in OF 2.2.1
Old   October 7, 2013, 16:45
Default interPhaseChangeFoam and MRF in OF 2.2.1
Stefano Gaggero
Mashiro5 is on a distinguished road
Dear OF users,,
I would like to compute cavitating flows for rotating geometries that, in non cavitating conditions, can be successfully computed using simpleFoam with MRF source (i.e. marine propellers in uniform inflow).
My question is: is the MRF source available also for the interPhaseChangeFoam through the fvOption dictionary (as for simpleFoam that now inherently include the functionalities of the old MRFSimpleFoam), or I need to build a custom solver ?
Thank You!
Mashiro5 is offline   Reply With Quote
Old   October 18, 2013, 05:31
Artur's Avatar
Artur
Artur will become famous soon enough
As far as I know interChangePhaseFoam is based on the PIMPLE algorithm so perhaps it would be easier for you to combine interDyMFoam and interChangePhaseFoam and use sliding meshes to solve your problem?
Best of luck,
A
Artur is offline   Reply With Quote
MRF solvers give diffenrent results when MRF zone's diameter is different sharonyue OpenFOAM Running, Solving & CFD 10 May 31, 2022 04:46
Simulation of Radial Fan with simpleFoam MRF nash OpenFOAM Running, Solving & CFD 2 November 5, 2015 10:12
[ICEM] ICEM MRF Interface - Penetrating Elements survADe ANSYS Meshing & Geometry 9 February 4, 2015 02:26
Should an empty MRF zone really induce this much cross-flow? sylvester OpenFOAM 5 November 18, 2010 03:48
Moving Mesh and MRF Romain FLUENT 1 May 16, 2002 03:45
