Doubt in scalarTransportFoam...
Like Tree2Likes
  • 1 Post By Hiroshiman
  • 1 Post By bbmorales
Old   June 25, 2013, 07:03
Default Doubt in scalarTransportFoam...
Abhiroop
AB08 is on a distinguished road
Hi I m new to OpenFoam nd need sm help........
What is the function of fvOptions in the following??
#include "fvCFD.H"
#include "fvIOoptionList.H"
#include "simpleControl.H"
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
#include "createFields.H"
#include "createFvOptions.H"
simpleControl simple(mesh);
Info<< "\nCalculating scalar transport\n" << endl;
#include "CourantNo.H"
while (simple.loop())
Info<< "Time = " << runTime.timeName() << nl << endl;
while (simple.correctNonOrthogonal())
solve
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(DT, T)
fvOptions(T)
runTime.write();
Info<< "End\n" << endl;
return 0;
AB08 is offline   Reply With Quote
Old   June 25, 2013, 10:59
Hiroshiman is on a distinguished road
fvOptions is a new feature of OF2.2.0 :
http://www.openfoam.org/version2.2.0/fvOptions.php
Here it contains the source term of the scalar transport equation.
vbnhfylbh likes this.
Hiroshiman is offline   Reply With Quote
Old   June 25, 2013, 16:16
Post
Abhiroop
ok... thnx Hiroshiman
Old   August 13, 2013, 05:40
Bayard Morales
bbmorales is on a distinguished road
Hello, colleagues
As of OF 2.2.0, the source term of scalarTransportFoam can be described in the file fvControl, due the code lines
solve
fvm::ddt(T)
+ fvm::div(phi, T)
fvOptions(T)
My question is:
Using fvOptions, how to build a point source term?
I wasn't able to find documentation or examples of it.
I don't even know which optin of fvOptions to use.
Where can I find do documentation on this?
Many thanks
bbmorales is offline   Reply With Quote
Old   October 8, 2013, 05:19
Bayard Morales
[SOLUTION]
https://github.com/OpenFOAM/OpenFOAM...stem/fvOptions - you can see some examples here
to define a source point, add these lines in the fvOption file.
scalarTracer                          //this is only the name of the object, can be anything
   type                      scalarSemiImplicitSource;
   active                    true;     //turns on and off the source
   timeStart                 0;        //starting time
   duration                  1;        //duration in seconds
   selectionMode             points;   //it could be also a cellZone
   points                             //list of coordinates of the source terms
      (0.1 0 0)
   scalarSemiImplicitSourceCoeffs
      volumeMode            absolute;   //     - absolute: values are given as \<quantity\> specific: values are given as \<quantity\>/m3
      injectionRateSuSp                // just a name
         T                   (0.01 0);   // T - scalar variable. First value = S_u (explicit source term); Second value = S_p.
Cheers
cfdonline2mohsen likes this.
Old   October 8, 2013, 07:41
thank you for sharing, that can be useful.
Regards.
ScalarTransportFoam for RTD calculations santoo_cfd OpenFOAM Running, Solving & CFD 39 July 12, 2021 01:15
scalarTransportFoam erased my original data and has very slowly transport results foamWang OpenFOAM Running, Solving & CFD 3 October 31, 2013 02:51
Problem with scalarTransportFoam illistrated using pitzDaily tutorial mlawson OpenFOAM 2 January 18, 2011 13:39
flux seems not conserved in my modified scalarTransportFoam danielr OpenFOAM Running, Solving & CFD 3 October 5, 2009 16:05
Fluent Basic Doubt Fluent learner FLUENT 16 May 30, 2008 04:09
