October 12, 2013, 08:24 |
modified interPhasechangeFoam base Temp
Mohammad Bahreini
Rep Power: 13 |
Hello foamers
I have managed to implement the interPhaseChangeFoam solver according to the project done by Martin Andersen [http://www.google.com/url?sa=t&rct=j...3899372,d.cGE]. I have also modified the solver to take the account of variable diffusion coefficient [DT ] based on the volume fraction of both phases. I have successfully compiled the solver and managed to get reasonable results on tutorial case. However, when I try to use this solver on my own case, I get completely wrong results. [A 2D case(pipe) that in bottom temperature 5 k more than saturation temperature and All of the wall velocity and pressure is zero gradient ]. After just a few time steps, temperature goes very high (higher than 200000 k) in just a few cells at the corner of the geometry, as I think it’s the problem of singularity. Meanwhile, water phase evaporates quickly in a very short period of time. I have tried different mesh size and boundary condition and the problem is still there. I have attached the solver and my test case here, so you guys can kindly help me get through this issue. Regards and thank you in advance link upload: http://www.uplooder.net/cgi-bin/dl.c...963f28b866e1c5 http://www.uplooder.net/cgi-bin/dl.c...03cc17ab200e16 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
OpenFOAM 1.6.x - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 68 | April 22, 2013 11:03 |
interFoam & decomposition method: scotch | MacGyver | OpenFOAM Running, Solving & CFD | 2 | May 23, 2012 07:00 |
openfoam 1.6 on debian etch | romant | OpenFOAM Installation | 9 | May 6, 2010 02:26 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
