Parabolic velocity profile in a rectangular channel
Like Tree1Likes
  • 1 Post By timbojones
Old   October 26, 2013, 10:12
Default Parabolic velocity profile in a rectangular channel
Nithish
nithishgupta is on a distinguished road
We are trying to obtain a parabolic velocity profile in a rectangular channel subjected to laminar flow,but we are unable to obtain the desired velocity variation instead we are getting a maximum value through out the y axis except the edges instead of obtaining the maximum value at the centre with the variations along the axis.Attached are the files for velocity and pressure.we request help regarding the check for the boundary conditions and clarifications on them.And also please check the velocity plotted along the y axis.
0.zip
nithishgupta is offline   Reply With Quote
Old   October 27, 2013, 16:31
Default Test or BC
timbojones is on a distinguished road
nithishgupta,
Are you seeking the duct solution as an Open FOAM test or to serve as an inlet BC in a different problem? If it's the latter, note there's a closed-form solution (though it's an infinite series solution) for fully-developed laminar flow. I don't have it with me, but can provide it in a day or two.
Timbojones
timbojones is offline   Reply With Quote
Old   October 28, 2013, 16:35
Nithish
That would be really helpful for me if you could post it.
Old   October 30, 2013, 05:39
Default Analytical solution for rectangular ducts...and more...
nithishgupta,
I was unhappy to learn that some of the CD-ROMs I had burned prior to leaving graduate school are no longer readable. My loss is not necessarily yours, though. I was able to find the closed-form solution posted on the internet at the following link.
http://www.engineering.uiowa.edu/~me...t1-updated.pdf
Expressions for velocity profile and flow rate in rectangular ducts can be found on page 13, eqns (3-48) and (3-49), respectively. You can use (3-49) in conjunction with your desired flow rate to determine the required pressure gradient to use in (3-48) and compute the velocity profile.
I hope this helps.
Regards,
Timbojones
Hackerbrucke likes this.
UDF Unsteady velocity parabolic profile Rashad FLUENT 3 October 1, 2018 15:27
UDF to apply a Spanwise velocity wave on a whole 3D rectangular channel domain QBeast Fluent UDF and Scheme Programming 8 October 15, 2013 05:10
How to apply an outlet velocity profile to another inlet? siw FLUENT 4 April 10, 2013 11:19
tecplot 3D velocity contours inside a channel vetnav Tecplot 4 July 14, 2010 20:03
How to create a parabolic velocity profile Nelson FLUENT 0 July 7, 2005 02:49
