ERROR : Floating point exception (core dumped)
Old   December 2, 2013, 05:37
Post ERROR : Floating point exception (core dumped)
sam.ho is on a distinguished road
Hi ,
I am simulating a steady state turbulent flow inside a valve using simpleFOAM.
The valve has 1 inlet and 4 outlets
Boundary Conditions INLET OUTLET
Velocity 0.27 m/s zeroGradient
pressure freestreamPressure fixedvalue 0
and all other boundaries like spring, spring support and valve body as no-slip condition and zero gradient pressure condition.
I am getting an error which has been attached with this post. Please look in to the problem and let me know how to avoid this error.
File Type: jpg Screenshot from 2013-12-02 16:06:00.jpg (88.2 KB, 26 views)
sam.ho is offline   Reply With Quote
Old   December 2, 2013, 07:54
Antimony is on a distinguished road
Your continuity error is basically 1e19! Your simulation has diverged. Check your boundary conditions. Or perhaps post the case here.
Regards,
Antimony
Antimony is offline   Reply With Quote
Old   December 3, 2013, 04:05
Post By switching off the turbulence model
I just switched off the turbulence model and run the case( with same boundary conditions) . Its running fine with continuity error decreasing as we can see in the attachment .
But why its not running when we switch on the turbulence model ?
Any suggestions ?
File Type: jpg Screenshot from 2013-12-03 14:31:30.jpg (77.3 KB, 11 views)
Old   December 3, 2013, 04:20
May I ask why is the p equation being solved three times within the same time step? Can you post your case without the mesh here?
Regards,
Antimony
Old   December 3, 2013, 05:25
Post Case files
[FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application simpleFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 100;
deltaT 10e-6;
writeControl timeStep;
writeInterval 10000;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 8;
runTimeModifiable true;]
[FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss upwind;
div(phi,k) bounded Gauss upwind;
div(phi,epsilon) bounded Gauss upwind;
div(phi,R) bounded Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) bounded Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
[FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.01;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0.1;
k
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
epsilon
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
R
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
nuTilda
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 2;
pRefCell 101;
pRefCell 58;
pRefCell 767;
pRefCell 527;
pRefValue 0;
residualControl
p 1e-2;
U 1e-3;
"(k|epsilon|omega)" 1e-3;
relaxationFactors
fields
p 0.3;
equations
U 0.5;
k 0.5;
epsilon 0.5;
R 0.5;
nuTilda 0.5;
pimpleDyMFoam constantly giving floating point exception and solution divergence fedvasu OpenFOAM Running, Solving & CFD 0 November 28, 2013 00:53
Ercoftac centrifugal pump case study bug, Openfoam 1.6-ext (Floating point exception) ArianeJasmin OpenFOAM Programming & Development 1 April 4, 2012 14:11
Finished simulation doesn't start: floating point exception [Divide by zero] MaxCFD STAR-CCM+ 3 June 26, 2011 10:31
Flouting point exception twoPhaseEulerFoam - I set delta t cristina87 OpenFOAM 1 May 26, 2011 15:35
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
