chtMultiRegionSimpleFoam between 2.1.x and 2.2.x
Old   December 6, 2013, 12:26
Default chtMultiRegionSimpleFoam between 2.1.x and 2.2.x
David
NewtoFOAM is on a distinguished road
Hi all,
I am struggling to get heat transfer in my solid regions for my chtMultiRegionSimpleFoam simulations in version 2.2.2. However the same case in 2.1.1 runs perfectly. I must be doing something daft.
I've made two cases, one to fit the format of 2.1.1 and the other to fit with 2.2.2. The case is a simple 2d counterflow heat exchanger with three regions (that I kindly borrowed from http://goo.gl/0RSgaf) which is simply two fluid regions separated by a solid region.
If you run the 2.2.2 case you'll notice a trivial amount of heat transfer inside the solid region. It's baffling to me.
I'd be grateful for any input into this. Is it just a case of my not translating the bc/material properties properly? The reason I ask is because all my other cht cases in 2.2.2 exhibit the same behaviour.
Thanks!
Dave
NewtoFOAM is offline   Reply With Quote
[ImmersedBoundary] Is Immersed Boundary Method already available in OF 2.1.x or 2.2.x keepfit OpenFOAM Community Contributions 16 April 27, 2016 07:24
Differences between 2.2.x and 2.2.1? phsieh2005 OpenFOAM 2 July 13, 2013 16:55
pimpleDyMFoam failed in tutorial cases (2.2.x) waku2005 OpenFOAM Running, Solving & CFD 3 May 13, 2013 04:28
Multiple lagrangian injection models in OF 2.2.x mturcios777 OpenFOAM Programming & Development 1 March 19, 2013 15:27
Tips to rebuild a thermodynamic model from 2.1.x to 2.2.x Tobi OpenFOAM Programming & Development 0 March 18, 2013 07:02
