Wind Turbine Similation
Old   May 11, 2011, 08:54
Default Wind Turbine Similation
Seg-Far is on a distinguished road
Hye everyone.
I am a new user who just started with OpenFoam 1.7.1 recently. I am trying to simulate with the k-epsilon model the flow over a wind turbine vertical (VAWT) .
The meshing is a non structural mesh realised with salome.
I would like to have some help for the choose of the solvers:
i read in the tutorial that the MRFSImple or simplSRF are betters for this kind of simulation.
Wich one choose?
Then, i hope to realise a dynamical simultaion wind a blade and a body who turn.
That why i need to define a Ggi interface . THe problem is that, i dont find the ggi commande in openFOam 1.7.1.
MRFZONES:
1
pales
wall (pales);
origin origin [0 1 0 0 0 0 0] (0.4 0 0);
axis axis [0 0 0 0 0 0 0] (0 0 1);
omega omega [0 0 -1 0 0 0 0] 50;
dynamicsMeshDict:
dynamicFvMeshLib "libtopoChangerFvMesh.so";
dynamicFvMesh mixerGgiFvMesh;
mixerGgiFvMeshCoeffs
coordinateSystem
type cylindrical;
origin ( 0 0 0 );
axis ( 0 0 1 );
direction ( 1 0 0 );
rpm 477;
slider
moving (ggiInside);
static (ggiOutside);
SOme Help Please.
Seg-Far is offline   Reply With Quote
Old   May 12, 2011, 07:20
taner is on a distinguished road
Hi Seg,
my experience is that MRFSimpleFoam works better than SimpleSRFFoam.
And you have to install the extended version to use GGI, e.g. openfoam-1.6-ext.
Taner
taner is offline   Reply With Quote
Old   May 16, 2011, 05:37
Originally Posted by taner View Post
Hi Seg,
Taner
Thanks for your reply.
I didn't know , if it's poosbille to install a extended version of OPENFOAM 1.6 knowing that i use OPENFOAM 1.7.
Are there a other means thanks to OPENFOAM 1.7.1, to define a rotating mesh?
I would like to realise a simulation like that:
http://www.youtube.com/watch?v=1xZ3W3ST1Lo
As you see there are a party that leads the movement to another. With the tools dynamicsMeshdict is not possible to define that?
Farid
Old   January 24, 2014, 05:43
Julian Langowski
Ruli is on a distinguished road
Originally Posted by Seg-Far View Post
Then, i hope to realise a dynamical simultaion wind a blade and a body who turn. That why i need to define a Ggi interface.
Dear Seg-Far,
as I understand, you also can simulate a non-rotating nacelle and a rotating blade with MRFSimpleFoam, so you don`t have to use GGI.
Bye
Julian
πάντα ῥεῖ - Heraclitus
Ruli is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
please help in simulating a wind turbine blade in 6 DOF ????.... usman naseer Main CFD Forum 2 March 10, 2016 02:53
Ducted wind turbine (BC for the shroud) Pepita CFX 4 June 29, 2013 07:09
Wind turbine simulation Saturn FLUENT 1 June 16, 2006 02:12
Wind turbine simulation Saturn Main CFD Forum 1 June 12, 2006 03:57
