Using shipFoam the tank slowly runs empty
Old   February 10, 2014, 10:46
Default Using shipFoam the tank slowly runs empty
Manoj
manoj_nav is on a distinguished road
Hi all
I am new to OF and I am using shipFoam under OF1.6 to simulate flow around ship hull in calm water and with waves. But as the simulation progresses, the tank slowly empties. Please help me to identify the issue.
I have given following input to alpha, p and U under folder '0'.
Alpha :
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object alpha;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
Inlet
type fixedValue;
value uniform 1;
Outlet
type inletOutlet;
inletValue uniform 0;
value uniform 1;
Top
type inletOutlet;
value uniform 0;
sides
type symmetryPlane;
hull_wall
type zeroGradient;
p :
FoamFile
version 2.0;
format ascii;
location "0";
object pd;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
Inlet
type zeroGradient;
Outlet
type zeroGradient;
Top
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 0;
value uniform 0;
sides
type symmetryPlane;
hull_wall
type zeroGradient;
U:
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0.5 0 0);
boundaryField
Inlet
type surfaceWaveVelocity;
phi phi;
value uniform (0.5 0 0);
Outlet
type inletOutlet;
inletValue uniform (0 0 0);
Top
type pressureInletOutletVelocity;
sides
type symmetryPlane;
hull_wall
type movingWallVelocity;
value uniform (0 0 0);
Regards,
Manoj
manoj_nav is offline   Reply With Quote
channel, inlet, outlet, shipfoam
interFoam / bubbleFoam to simulate an aerated tank Meratb OpenFOAM Running, Solving & CFD 3 November 6, 2020 11:45
Need Help! High pressure Gas discharge from tank to tank through a pipe superarthur86 FLUENT 2 June 16, 2017 10:22
Simple Water Tank Transient 88phil88 CFX 5 March 17, 2014 03:48
Mixture and Decay of a tracer in a Water Tank Jeffrey1992 CFX 2 July 27, 2012 13:31
Blow Tank Simulation ... Need Help! treyevans CFX 1 February 20, 2010 00:42
