Modelling rotating machinery other than AMI rotating meshes
Old   March 4, 2014, 06:42
Red face Modelling rotating machinery other than AMI rotating meshes
fedvasu is on a distinguished road
Hi Foamers,
I have case of a rotating fan at Low- speed ie about 300-400 rpm. I have successfully carried out RAS simulations using cyclicAMI approach where, the motion of the fan is modeled as rigid body rotation of a cylindrical AMI mesh section, which has same speed as our fan. I have tried various levels of mesh refinement and differing y+ and so forth.
The screen shot is attached.
I would like to know if there are any other methods of modelling this problem, as I am not able to predict some important parameters accurately. For the attached mesh I used solidBodyMotionFvMesh for rotating inner domain/cyclicAMI. I am looking into
dynamicFvRefineFvMesh and dynamicMotionSolverFvMesh for rotating the fan.
please help understand other approaches and mesh solvers (pointers to examples would be great)
fedvasu is offline   Reply With Quote
Old   March 5, 2014, 09:55
Julian Langowski
Ruli is on a distinguished road
Dear Fedvasu,
have a look at the MRF approach using the fvOptions in the system folder.
Basically you use a static mesh and add additional source terms (Coriolis acceleration) to the Navier Stokes equation.
I think a tutorial can be found in incompressibel/simple somewhere.
Best regards
Julian
πάντα ῥεῖ - Heraclitus
Ruli is offline   Reply With Quote
Old   March 6, 2014, 03:18
Red face error in solver
Originally Posted by Ruli View Post
Dear Fedvasu,
Best regards
Julian
Hi Ruli,
I have set-up the case with fvOptions I am giving my top and bottom cylinder caps freeStream Boundary condition but I am getting following error, previously I was giving all wall boundary condition but still same error, In my case there is no inflow or outflow, all the flow is due to rotation of fan. I could share my 0.org if required.
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 0.455568
Specified mass inflow : 0.493281
Specified mass outflow : 0.493281
Adjustable mass outflow : 0
Old   March 6, 2014, 05:34
Red face making both top and bottom caps empty
I got this error for empty boundary condition
--> FOAM FATAL ERROR:
Total flux              : 0.0686486
Specified mass inflow   : 0.518823
Specified mass outflow  : 0.518823
both inflow and outflow is same, i don't know what the problem is now!!
Old   March 6, 2014, 11:13
Default Solved by initializing with potentialFoam
I studied motorBike case ($FOAM/mesh/snappyHex/motorBike), I too initialized values with potentialFoam and I am running the simulation now.
I would like to know are there any other methods which involve moving geometry instead MRF, to model this kind of problem
I was thinking dynamicMotionSolverFvMesh of dynamicMeshDict, has anyone any experience in modeling these kind of problems??
please let me know.
Old   March 6, 2014, 11:45
Julian Langowski
Try this one:
tutorials/incompressible/simpleFoam/mixerVessel2D
Best regards
Julian
Old   March 7, 2014, 01:35
Try this one:
Best regards
Julian
Yes,
The current case which I am running is set-up like mixerVessel2D.
See I have taken two approach one with mesh motion where solidBodyMotionSolverFvMesh (I have results and analyzed them) is used for dynamic part of the mesh and another is MRF approach which you have helped me to set-up.
I am asking if there is yet another approach perhaps with mesh motion but different mesh-motion solver??
dynamic mesh, openfoam
2D modelling of flow past a rotating cylinder pds24 Main CFD Forum 1 August 21, 2015 10:50
modelling thin rotating rod doctsh Fidelity CFD 0 November 7, 2009 03:17
modelling a rotating cylinder in fluent?rply asas taimoor FLUENT 3 February 27, 2009 07:03
Modelling Heat Convection in a Rotating Disk Rob Windram FLUENT 0 February 27, 2009 06:09
Particle tracking in unsteady rotating meshes? BP Siemens 3 October 14, 2003 07:44
