Large contrasting values across adjacent cells
Like Tree3Likes
  • 1 Post By piu58
  • 1 Post By Joshua14
  • 1 Post By piu58
Old   June 26, 2017, 08:34
Default Large contrasting values across adjacent cells
sturgeon is on a distinguished road
Hi all
Apologies as this is very basic, trying to learn OpenFOAM in preparation for more complex sims. I am running a simple 2D case in potentialFoam, where air is entering from the left and exiting at the top and right, encountering a triangular ridge in the centre. In the solution however I am getting large contrasting values across the cells. (http://i.imgur.com/EqrlL0y.png) I am guessing it is due to the mesh, but checkMesh registers it as okay and I've messed around with increasing cell count/grading with no success.
The mesh: http://i.imgur.com/kobL1OJ.png
Mesh zoomed to the area of contrast: http://i.imgur.com/4ylAZHa.png
blockMeshDict:
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
(0 100 -0.5)
(46.25 100 -0.5)
(50 100 -0.5)
(53.75 100 -0.5) //3
(100 100 -0.5) //4
(0 5.47 -0.5)
(46.25 5.47 -0.5)
(50 11.99 -0.5)
(53.75 5.47 -0.5) //8
(100 5.47 -0.5) //9
(0 0 -0.5)
(43.09 0 -0.5)
(44.23 0 -0.5)
(47.115 5 -0.5)
(50 10 -0.5)
(52.885 5 -0.5)
(55.77 0 -0.5)
(56.91 0 -0.5)
(100 0 -0.5)
(0 100 0.5)
(46.25 100 0.5)
(50 100 0.5)
(53.75 100 0.5)
(100 100 0.5)
(0 5.47 0.5)
(46.25 5.47 0.5)
(50 11.99 0.5)
(53.75 5.47 0.5)
(100 5.47 0.5)
(0 0 0.5)
(43.09 0 0.5)
(44.23 0 0.5)
(47.115 5 0.5)
(50 10 0.5)
(52.885 5 0.5)
(55.77 0 0.5)
(56.91 0 0.5)
(100 0 0.5)
blocks
    hex (5 6 1 0 24 25 20 19) (25 25 1) simpleGrading (0.02 50 1)
    hex (6 7 2 1 25 26 21 20) (50 25 1) simpleGrading (1 50 1)
    hex (7 8 3 2 26 27 22 21) (50 25 1) simpleGrading (1 50 1)
    hex (8 9 4 3 27 28 23 22) (25 25 1) simpleGrading (50 50 1)
	hex (10 11 6 5 29 30 25 24) (25 50 1) simpleGrading (0.02 1 1)
	hex (11 12 13 6 30 31 32 25) (25 50 1) simpleGrading (1 1 1)
	hex (13 14 7 6 32 33 26 25) (50 25 1) simpleGrading (1 1 1)
	hex (14 15 8 7 33 34 27 26) (50 25 1) simpleGrading (1 1 1)
	hex (15 16 17 8 34 35 36 27) (50 25 1) simpleGrading (1 1 1)
	hex (17 18 9 8 36 37 28 27) (25 50 1) simpleGrading (50 1 1)
edges
boundary
    inlet
        type patch;
        faces
			(10 5 24 29)
			(5 0 19 24)
    outlet
        type patch;
        faces
			(0 1 20 19)
			(1 2 21 20)
			(2 3 22 21)
			(3 4 23 22)
			(4 9 28 23)
			(9 18 37 28)
    fixedWalls
        type wall;
        faces
			(11 10 29 30)
			(12 11 30 31)
			(13 12 31 32)
			(14 13 32 33)
			(15 14 33 34)
			(16 15 34 35)
			(17 16 35 36)
			(18 17 36 37)
mergePatchPairs
Again, sorry this is basic; I have looked online and messed around in the files for a while without any success, so any advice would be appreciated.
Cheers
sturgeon is offline   Reply With Quote
Old   June 26, 2017, 14:11
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I think the solution you got may be physical plausible: There should be a large increasing in pressure at the top of the triangle. I think you gave the pressure here.
I say "plausible" and not "correct" because your problem is perhaps not a potential problem so the potential solution is only a first guess.
sturgeon likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   June 26, 2017, 15:00
Thank you piu. Sorry though, I should have been more clear - I meant the contrast between the light blue triangular part and the darker blue surroundings, which aligns with the different blocks of the mesh, which made me feel like there was something wrong with the way I'd meshed it.
Old   June 26, 2017, 16:01
Joshua
Joshua14 is on a distinguished road
It looks like the culprit is the change in the cell orientation between these regions. You can either try remeshing with finer cells where there is larger changes between the regions, or try a different block structure.
Currently you use 10 different blocks. Maybe try less blocks. You can also always try to mesh with snappy.
Joshua
Joshua14 is offline   Reply With Quote
Old   June 26, 2017, 18:10
Joshua
Thank you Joshua, I will look into this and see if it resolves the issue. Cheers.
Old   June 27, 2017, 00:13
piu58's Avatar
Uwe Pilz
You used a triangular mesh. Such meshes are known to be diffusive, because they realize a first order approximation. I strongly recommend a hex mesh.
Uwe Pilz
Old   June 27, 2017, 08:23
I am attempting to rectify this but I don't understand how to get blockMesh to do this. The layout of my geometry was trying to mirror the cylinder case tutorial, which uses hexes and executes properly... but I don't see anything different about its blockMeshDict versus mine. Do the sharp edges prevent the use of hexes over triangles?
Old   June 27, 2017, 09:28
Rodrigo
guin is on a distinguished road
I believe Sturgeon didn't use a tetrahedral mesh. It is more likely a common visualization issue with ParaView, which decomposes the polyhedral elements into tetrahedra for any good reason I still ignore. You can see the correct mesh by unclicking the option Decompose polyhedra (see attached pics.).
Now coming back to your problem... my initial guess is that it is related with the sudden non-orthogonality in the transition regions.
1st question: Are you using nonOrthogonal correctors?
(fvSolution file -> nNonOrthogonalCorrectors)
2nd question: Are you using corrected schemes? (fvScheme file -> laplacianSchemes & snGradSchemes)
guin is offline   Reply With Quote
Old   June 27, 2017, 11:33
Attachment 56980
Attachment 56981
I believe you are correct about the mesh - I can't find that option in ParaView but when I disable the cell interpolation and just have them coloured by absolute value it's pretty clear they're not triangular.
My nNonOrthogonalCorrectors is set to 3, as it's copied directly from the cylinder case. Both of the schemes you mentioned are the corrected versions, like in the cylinder case.
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
[ICEM] Problem with prism cells sidharath ANSYS Meshing & Geometry 0 September 1, 2015 07:09
[snappyHexMesh] snappyHexMesh Segmentation Fault avd28 OpenFOAM Meshing & Mesh Conversion 11 May 11, 2015 20:32
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
