Actuator Disk Modeling in OpenFOAM
Old   February 27, 2014, 06:13
Post Actuator Disk Modeling in OpenFOAM
Ajay Singh
ajaysingh83 is on a distinguished road
Hi
I am quite new to OpenFOAM. I wanted to see the effect of rotor in fuselage. I adopted the approach of Actuator Disk Modeling and took the help from Erik Svenning report and his code. I could compile the code with some modification and generate the executable. I am able to run the case with new executable but I am facing problem to write the data like pressure and velocity at certain probe location. If I use the simpleFoam (as its there in OpenFOAM) It writes the data but if I use my executable, it does not write the file. Can somebody please help me to resolve this problem. I am using the following function in controlDict file to write the data.
functions
forces_fuselage
type forces;
functionObjectLibs ("libforces.so");
outputControl timeStep;
outputInterval 10;
patches
fuse
pName p;
UName U;
rhoName rhoInf;
log true;
rhoInf 1.205;
CofR (7.0358 0 1.6129); //momnet point
ajaysingh83 is offline   Reply With Quote
actuator disk, helicopter, libforces.so, output data
Memory protection in OpenFOAM / combinig with FORTRAN botp OpenFOAM Programming & Development 2 February 15, 2016 12:25
[Gmsh] gmsh 2.6.0 conversion to OpenFoam 160 rosswin OpenFOAM Meshing & Mesh Conversion 0 March 5, 2013 07:34
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
OpenFOAM Training in Europe and USA hjasak OpenFOAM 0 August 8, 2008 05:33
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
