icoFsiElasticNonLinULSolidFoam - simulation does not start |
February 27, 2014, 09:19 |
Rep Power: 12 |
Hi guys,
I am trying to setup an icoElasticFsi...simulation. Therefore I copied the HronTurek TestCase from foam-extend3.0 and changed the settings to my 3D Mesh settings. My testcase is a simple finite flap in an couette channel. My fluid boundaries are: in, out (cyclicGgi), top (moving wall), bottom (no slip wall) and the both channelsides (slip walls). The flap itself ist called "cyl" My solid boundaries are: cyl_fixed and cyl_solid -> fixed is the ground patch of the flap and solid is the moving part. When I run icoFsiEl....I got following error immediatly: Code:
Create time Create dynamic mesh for time = 0 --> FOAM Warning : From function dlLibraryTable::open(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 85 could not load libmesquiteMotionSolver.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dynamicFvMesh::New(const IOobject& io) in file dynamicFvMesh/newDynamicFvMesh.C at line 42 Loading of dynamic mesh library libmesquiteMotionSolver.so unsuccesful. Some dynamic mesh methods may not be available Selecting dynamicFvMesh dynamicMotionSolverFvMesh Initializing the GGI interpolator between master/shadow patches: in/out Selecting motion solver: laplace Selecting motion diffusivity: quadratic Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Reading incremental displacement field DU Patch cyl_solid Traction boundary field: DU nonLinear set to updated Lagrangian --> FOAM Warning : The gradScheme for DU should be "extendedLeastSquares 0" for the boundary non-orthogonal correction to be right Reading incremental displacement field DV Reading accumulated velocity field V Reading accumulated stress field sigma Reading incremental stress field DSigma Selecting rheology model linearElastic Creating constitutive model Floating point exception Maybe you can help me, cause the error log is not given that much information. In the original Turek Totorial would be the next step after "Creating constitutive model" Code:
Reading coupling properties Create fluid-to-solid and solid-to-fluid interpolators Check fluid-to-solid and solid-to-fluid interpolators Fluid-to-solid face interpolation error: 1.24127e-16 Solid-to-fluid face interpolation error: 1.24127e-16 Thank you for your help Last edited by hxaxtma; February 27, 2014 at 11:17. |
March 3, 2014, 07:44 |
Rep Power: 12 |
no one has any idea?
March 5, 2014, 08:35 |
Rep Power: 12 |
Ok simple Error, but I forgot to set TwoDMotion to no: Well now I got immediatly a floating point error after 1 interation. Any idea why?
Create time Create dynamic mesh for time = 0 --> FOAM Warning : From function dlLibraryTable::open(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 85 could not load libmesquiteMotionSolver.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dynamicFvMesh::New(const IOobject& io) in file dynamicFvMesh/newDynamicFvMesh.C at line 42 Loading of dynamic mesh library libmesquiteMotionSolver.so unsuccesful. Some dynamic mesh methods may not be available Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: laplace Selecting motion diffusivity: quadratic Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Reading incremental displacement field DU Patch plate Traction boundary field: DU nonLinear set to updated Lagrangian --> FOAM Warning : The gradScheme for DU should be "extendedLeastSquares 0" for the boundary non-orthogonal correction to be right Reading incremental displacement field DV Reading accumulated velocity field V Reading accumulated stress field sigma Reading incremental stress field DSigma Selecting rheology model linearElastic Creating constitutive model Reading coupling properties Create fluid-to-solid and solid-to-fluid interpolators Check fluid-to-solid and solid-to-fluid interpolators Fluid-to-solid face interpolation error: 1.78415e-15 Solid-to-fluid face interpolation error: 1.78415e-15 Starting time loop Time = 1e-05 Selecting coupling scheme Aitken Time = 1e-05, iteration: 1 Current fsi under-relaxation factor: 0.01 Maximal accumulated displacement of interface points: 0 Courant Number mean: 0 max: 0 velocity magnitude: 0 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 8.89011e-14, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 4.03802e-11, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.98383e-11, No Iterations 1 Floating point exception |
May 19, 2015, 03:26 |
Stephanie
Rep Power: 11 |
Hey,
I get now the same mistake. After 20 seconds the simultaions allways interrupts. Did you find any solution? best regards, Stephie |
September 5, 2017, 03:19 |
How to use icoFsiElasticNonLinULSolidFoam? Looking forward to a testcase.
songchang
Hey,
I am trying to setup an icoElasticFsi...simulation. Glad to hear that the solver icoFsiElasticNonLinULSolidFoam can make it. Anybody can give me detailed guidance on the HronTurek TestCase using openfoam 4.0? The necessary code file and Instruction about the entire process will be more useful. Looking forward to your reply. |
September 19, 2017, 13:51 |
#6 | |
GS
Rep Power: 10 |
I installed Foam extend 3.2 in order to work on icoFsiElasticNonLinULSolidFoam solver. |
January 9, 2019, 08:05 |
Rep Power: 7 |
January 18, 2019, 12:02 |
Hojatollah Gholami
Rep Power: 7 |
I change the materials properties as the HronTurek's study (FSI2) and the structure start to oscillate.
March 20, 2019, 23:03 |
details
#9 | |
Rep Power: 7 |
Yeah,i use foam-extend4.0,and i also change the materials properties(E),but i can't get a stable oscillate,do you have the same situation? or can you provided what properties did you change? Thank you. |
March 21, 2019, 00:05 |
Hojatollah Gholami
Rep Power: 7 |
Dear Popa
I uses FSI2 of hronTurek study. the stable simulation achieve with fsiFoam |
March 21, 2019, 01:58 |
Dear Hgholami
#11 | |
Rep Power: 7 |
What version of openFoam do you use?I haven't the solver fsiFoam in form_extend4.0,and once,i did use a tool(http://openfoamwiki.net/index.php/Ex...re_interaction) and get the result and its solver is just the fsiFoam. Do you do so or other ways? Thank you. |
March 21, 2019, 02:52 |
#12 |
Hojatollah Gholami
Rep Power: 7 |
YES. I uses toolkit of openFoam-ext4.0 and then fsiFoam
October 18, 2019, 03:16 |
#13 |
chandra shekhar pant
Dear All,
In this regard I have a query, I already have OpenFoam 19.06, do I need to install OpenFoam-extend-4.0? If I install OpenFoam-extend-4.0 in the same workstation, will the mess up ? My ultimate aim is to install OpenFPCI, which essentially requires "both OpenFOAM-Extend and ParaFEM are compiled on the system, using the Open-MPI available on the system". Any help/suggestion is welcomed. Thanks! |
Problem in initializing transient simulation with a finer mesh | sidd | CFX | 8 | April 29, 2016 02:25 |
Discrete event simulation vs. fixed time (discrete time simulation) | jenjon | FLUENT | 0 | March 10, 2013 06:58 |
Simulation and Optimisation of centrifugal fan 3D to 2D | eRzBeNgEl | STAR-CCM+ | 0 | January 31, 2013 13:21 |
Using 'define init' macro to perform a calculation at the start of a simulation | jonnythewlis | FLUENT | 0 | May 21, 2010 07:23 |
Replacing mesh while running a simulation | akultane | CFX | 1 | November 15, 2009 13:46 |
