simpleFoam - Change physical properties of liquid
Old   March 5, 2014, 05:06
Question simpleFoam - Change physical properties of liquid
vut
vut is on a distinguished road
I am new user of OpenFoam. I would like to ask for help in modifying the physical properties of liquid which are:
- mass density
- viscosity
Thanks in advance.
T
vut is offline   Reply With Quote
Old   March 5, 2014, 05:44
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
kinematic viscosity of the fluid is kept in constant/transportProperties file. Density is not actually used in simpleFoam as fluid is incompressible.
alexeym is offline   Reply With Quote
Old   March 5, 2014, 08:34
Question
vut
Thank you, Alexey, for your answer.
I am not sure but in the system of equations for RANS, we have rho (mass density of fluid) and nut (kinematic turulent viscosity), right?
May we change them somewhere in OpenFOAM?
T
Originally Posted by alexeym View Post
Old   March 5, 2014, 09:28
Alexey Matveichev
T
For incompressible fluid we can divide equations by density, so there will be no density and just kinematic viscosity.
OpenFOAM uses nuEff = nu + nut, where nu is kinematic viscosity of a fluid and you change it in constant/transportProperties, nut is calculated by turbulence model and again AFAIK there is no density in equations (well, you can pass density field to the model, but there's no density field in simpleFoam) as it is non-zero constant so we again can divide equations by it.
Old   March 6, 2014, 04:32
vut
OK, I understand what you mean.
Thanks for your answer.
T
Air physical properties at high temperatures zombiaska Main CFD Forum 2 March 12, 2012 17:59
Drastic change in properties across a region trinath2rao Main CFD Forum 1 April 27, 2011 11:17
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
physical properties used in CFD codes Craig Branch Main CFD Forum 2 September 28, 2004 03:35
Properties of liquid Hydrogen. Santosh Kumar Mukka Main CFD Forum 0 July 29, 2003 20:43
