presenting non-integer elemnet compositions in species chemkin
Old   March 7, 2014, 03:56
Default presenting non-integer elemnet compositions in species chemkin
Thamali
Thamali is on a distinguished road
I have two questions regarding presenting a reactions in OpenFoam.I tried using OF format as well as chemkin format.
  • In chemkin format I have the issue of representing following compostion.
C6H6.2O0.2
Is there a way to represent an element composition like C6H6.2O0.2 in chemkin?
  • In OF format I cannot present following reaction and its rate.
CO + 0.5O2     => CO2
Reaction rate =kr Cco*Co2^0.5*Ch2o^0.5
I tried "thirdBodyIrreversibleArrheniusReactionRate",a nd it did not work.
And I tried to represent reaction in following methods as well.
CO + 0.5O2+H2O^0.5     => CO2+H2O
CO + 0.5O2 +0H2O^0.5        => CO2
If someone can help me,really appreciate.
Thanks.
Thamali is offline   Reply With Quote
Old   March 19, 2014, 22:51
Thamali
Okay.I solved the problem using both chemkin and OpenFOAM reaction files.For anyone who interested.
foamChemistryFile "$FOAM_CASE/constant/reactions";
foamChemistryThermoFile "$FOAM_CASE/constant/thermo.compressibleGas";
CHEMKINFile     "$FOAM_CASE/chemkin/chem.inp";
CHEMKINThermoFile "$FOAM_CASE/chemkin/therm.dat";
Thamali
Modelling Biomass Combustion via Species Transport Racheal FLUENT 39 January 8, 2022 07:42
How do I know wich species has which integer value? sega Fluent UDF and Scheme Programming 14 May 20, 2020 00:34
Adding species to chemkin Rickard.Solsjo OpenFOAM 3 August 16, 2018 10:34
OpenFoam using chemkin to make new species D.R. OpenFOAM Running, Solving & CFD 3 April 7, 2011 16:27
Species order fluent Raddi FLUENT 1 March 13, 2009 00:21
