Flow around a sphere using chtMultiRegionFoam
Old   March 16, 2014, 14:20
Default Flow around a sphere using chtMultiRegionFoam
Niccolo
Niccolo is on a distinguished road
Hi everyone,
I am new to openFoam. Hope someone can help me .
I am trying to simulate an isothermal, laminar flow around a sphere with chtMultiRegionFoam (after I'll try to model heat generation inside the sphere). My mesh domain is 6m x 6m x 6m with a 1.2m D sphere at the centre. I have imposed no-slip condition on the sphere, fixed velocity at the inlet, inletOutlet condition at the outlet and slip conditions at the other 4 boundaries. As for the pressure I used fixedValue at the outlet and zeroGradient at the inlet.
The problem I have is that it seems that instabilities are generated at one corner of the boundary so that I have backup flow at the outlet. These instabilities get worse with decreasing the velocity so I suspect has something to do with the solver settings
I attached the file I used in the simulation and the picture of a section of my system (Water is flowing left to right at 0.1 m/s)
Any help is greatly appreciated! Thank you!
Niccolo
Niccolo is offline   Reply With Quote
chtmultiregionfoam, flow around a sphere
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
[Other] Creating spherical domain for solving flow around a sphere jamessbriscoe OpenFOAM Meshing & Mesh Conversion 0 July 19, 2012 11:36
Flow past a sphere Fabio FLUENT 23 December 18, 2009 15:32
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
3D sphere flow MH Kim Main CFD Forum 1 August 8, 2005 17:06
