March 20, 2014, 09:43 |
Incompressible_simpleFoam_BC
Jiri
Rep Power: 13 |
Hi there,
please help me with the following: I wish to calculate 3D geometry as an incompressible k-epsilon model with boundary conditions - velocity inlet and pressure outlet (which is likely the most humble task). Below you can see the individual files. I would be very grateful for any help. I think the problem is especially in settings of k and epsilon.. Thank you very much wall-4 is inlet wall-5 is outlet. The folder 0/p: internalField uniform 0; boundaryField { //- Set patchGroups for constraint patches #include "${WM_PROJECT_DIR}/etc/caseDicts/setConstraintTypes" wall-4 { type zeroGradient; } wall-5 { type fixedValue; value uniform 0; } wall-3 { type zeroGradient; } wall-6 { type zeroGradient; } wall-7 { type zeroGradient; } } *************** The folder 0/U: internalField uniform (0 0 0); boundaryField { //- Set patchGroups for constraint patches #include "${WM_PROJECT_DIR}/etc/caseDicts/setConstraintTypes" wall-4 { type fixedValue; value uniform (0 0 1); } wall-5 { type zeroGradient; } wall-3 { type zeroGradient; } wall-6 { type zeroGradient; } wall-7 { type zeroGradient; } } ********************** The folder 0/epsilon: dimensions [0 2 -3 0 0 0 0]; internalField uniform 8.87; boundaryField { wall-3 { type zeroGradient; value uniform 8.87; } wall-4 { type freestream; freestreamValue uniform 8.87; } wall-5 { type zeroGradient; } wall-6 { type zeroGradient; value uniform 8.87; } wall-7 { type zeroGradient; value uniform 8.87; } } ******************* The folder 0/k: dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.0158; boundaryField { wall-3 { type zeroGradient; value uniform 0.0158; } wall-4 { type freestream; freestreamValue uniform 0.0158; } wall-5 { type zeroGradient; } wall-6 { type zeroGradient; value uniform 0.0158; } wall-7 { type zeroGradient; value uniform 0.0158; } } The folder 0/nut: dimensions [0 2 -1 0 0 0 0]; internalField uniform 0.14; boundaryField { wall-4 { type calculated; value $internalField; } wall-5 { type calculated; value $internalField; } wall-3 { type nutkWallFunction; value $internalField; } wall-6 { type nutkWallFunction; value $internalField; } wall-7 { type nutkWallFunction; value $internalField; } } **************** The folder system/controlDict: libs ( "libOpenFOAM.so" "libincompressibleTurbulenceModel.so" "libincompressibleRASModels.so" ); application simpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 150; deltaT 1; writeControl timeStep; writeInterval 10; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable true; ************************** The folder system/fvSchemes: ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss limitedLinearV 1; div(phi,k) bounded Gauss limitedLinear 1; div(phi,epsilon) bounded Gauss limitedLinear 1; div(phi,R) bounded Gauss limitedLinear 1; div(R) Gauss linear; div(phi,nuTilda) bounded Gauss limitedLinear 1; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } ********************* The folder system/fvSolution: solvers { p { solver GAMG; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; tolerance 1e-06; relTol 0.05; } pFinal { $p; tolerance 1e-06; relTol 0; } "(U|k|epsilon)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0.1; } "(U|k|epsilon)Final" { $U; tolerance 1e-05; relTol 0; } nuTilda { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0.1; } } PIMPLE { nOuterCorrectors 4; nCorrectors 1; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } SIMPLE { nNonOrthogonalCorrectors 0; residualControl { p 1e-2; U 1e-3; "(k|epsilon)" 1e-3; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.7; "epsilon.*" 0.7; } } cache { grad(U); } |
