July 2, 2019, 17:00 |
Problem with 3weeks Day2
Rep Power: 11 |
I tried to follow the Tutorial in the 3 week course, and on day2 it has Turtorial Three from http://cfd.at/downloads/FoamTutV4_3-ExampleThree.pdf.
The example ran fine until I tried to change the mesh density to 100 cells (as suggested by the tutorial), and then it solves up to time step 0.00459 when it crashes with a Negative initial temperature T0: -13.1838 Not sure what the issue is. |
July 2, 2019, 17:04 |
Rep Power: 11 |
**Edit** this was because I was comparing the 1 bar that I ran to the 10 bar that was reported. ***/edit**** I also was getting max Courant numbers of half that reported by the tutorial pdf.
July 2, 2019, 17:12 |
Rep Power: 11 |
Increasing the time step for the solution from 1 e-5 to 1 e-4 solves the problem, but I don't understand why a very small courant number would lead to unstable Temperatures causing the crash.
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
