rhoSimpleFoam :: Maximum number of iterations exceeded
Old   April 8, 2014, 08:18
Default rhoSimpleFoam :: Maximum number of iterations exceeded
adarsh tiwari's Avatar
adarsh tiwari
adarsh tiwari is on a distinguished road
Hi all,
I am trying to solve a case with time varying Boundary conditions using uniformValue and rhoSimpleFoam.
The input given for patches in p and T is in tabular form while the U is set as 'pressureInletVelocity'
It is solving upto 2 clock time while afterwards it says
Time = 0.0003
DILUPBiCG: Solving for Ux, Initial residual = 0.416261, Final residual = 2.23461e-07, No Iterations 10
DILUPBiCG: Solving for Uy, Initial residual = 0.46579, Final residual = 9.685e-07, No Iterations 10
DILUPBiCG: Solving for Uz, Initial residual = 0.417807, Final residual = 2.21784e-07, No Iterations 12
DILUPBiCG: Solving for h, Initial residual = 0.558075, Final residual = 1.35032e-08, No Iterations 3
--> FOAM FATAL ERROR:
From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const
in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::species::thermo<Foam::hConstThermo<Foam:er fectGas<Foam::specie> >, Foam::sensibleEnthalpy>::T(double, double, double, double (Foam::species::thermo<Foam::hConstThermo<Foam:e rfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam:e rfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam:e rfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double) const) const in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#3 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#4 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleEnthalpy> > > >::correct() in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/rhoPorousSimpleFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Aborted (core dumped)
I tried to resolve the issue using http://www.cfd-online.com/Forums/ope...implefoam.html
http://www.cfd-online.com/Forums/ope...-exceeded.html
but got the same results.
Now I changed the solver for 'p' from GAMG to DICPCG and next time to PCG (because I think that the problem is with 'p' only).
and still the same thing.
Please help me ASAP...
Thanks and Regards,
Adarsh Tiwari
adarsh tiwari is offline   Reply With Quote
Old   April 12, 2014, 01:56
Vojtech Betak
betakv is on a distinguished road
Dear Adarsh,
rhoSimpleFoam is a steady-state solver. If you want use time varying boundary condition try to use rhoPimpleFoam
betakv is offline   Reply With Quote
Old   April 14, 2014, 01:32
adarsh tiwari
Greetings Betakv,
I have already simulated using rhoPimpleFoam but I got some fancy results, with best of my knowledge I can say that the probability of getting appropriate results is much more higher in rhoSimpleFoam.
It would be great help if you provide me some tutorials about rhoSimpleFoam, I already have one, but it is not worth about this case.
Thanks and Regards,
Adarsh Tiwari
Old   April 14, 2014, 02:00
Vojtech Betak
Dear Adarsh,
there are number of reasons( boundary/initial condition, solver setting, ... ) why you got fancy results. Can you send description of your case?
Old   April 16, 2014, 03:20
adarsh tiwari
Greeting Betakv,
sorry for late reply.
The file is too large to upload hence i am attaching the brief version of the same but by removing some of the data-table entries.
In pressure files I have also tried with the uniformTotalPressure but still got nothing
in solution schemes also i have changed form GAMG to different solver. I have also tried with faceCente and cellCenter schemes.
Thanks and Regards,
Adarsh Tiwari
Old   April 16, 2014, 04:47
Vojtech Betak
Dear Adarsh,
you have quite lot of errors in boundary condition especially on the inlet and outlet.
On the inlet you have to prescribe a totalPressure bc for pressure. On the outlet you have to prescribe zeroGradient or inletOutlet bc for velocity and temperature
betakv
Originally Posted by adarsh tiwari View Post
Greeting Betakv,
Thanks and Regards,
Adarsh Tiwari
Old   April 22, 2014, 07:49
adarsh tiwari
hi Betakv,
As I already informed you that the p and T boundary conditions are fixed, only thing I can play with is U.
I used zeroGradient and inletOutlet bc for velocity with different combinations but still getting the same message out.
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 07:56
buoyantSimpleFoam and watertank Tobi OpenFOAM Running, Solving & CFD 100 December 18, 2022 08:15
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
