ExternalCoupled patch solving problem
Old   July 10, 2014, 10:55
Default ExternalCoupled patch solving problem
Michele Righi
Michele Righi is on a distinguished road
Hi everyone,
I have a problem to solve a case with an externalCoupled patch that impose the pressure on the boundary.
For example if I impose a sinusoidal law with a given amplitude and frequency using the GroovyBC method the solver works fine.
If I impose the same values with an externalCoupled patch method the timeStep of the solution falls down after few tenths of a second simulation and the solver stops.
I have checked that the value of amplitude and frequency are the same in the same time in both cases. But with GroovyBC everythink works very fine and with external program doesn't work at all.
Does someone have any idea on why this happen?
Thank you very much.
Michele
Michele Righi is offline   Reply With Quote
externalcoupled, groovybc, pressure, pressure boundary, solver
Simulation seems to converge but crashes suddenly xxxx OpenFOAM 16 September 12, 2014 08:07
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
