Simulation carshes after mappingFields
Old   April 23, 2014, 09:47
Default Simulation carshes after mappingFields
flux is on a distinguished road
Hi!
I was running a simulation with a wall function mesh and the k-omega SST model. After that, i copied the whole case and replaced the mesh with a finer one. The geometry and the boundary conditions are still the same so i used the command:
mapFields <source-dir> -consistent -sourceTime latestTime
After that, i started the new simulation. When OpenFOAM reaches the "Selecting RAS turbulence model kOmegaSST" i get a Floating point exception. The full error message is shown below.
Can anyone tell me what is wrong?
Thanks!
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#6  Foam::compressible::RASModels::kOmegaSST::F2() const at ??:?
#7  Foam::compressible::RASModels::kOmegaSST::F23() const at ??:?
#8  Foam::compressible::RASModels::kOmegaSST::kOmegaSST(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&, Foam::word const&) at ??:?
#9  Foam::compressible::RASModel::adddictionaryConstructorToTable<Foam::compressible::RASModels::kOmegaSST>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:?
#10  Foam::compressible::RASModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:?
#11
 at ??:?
#12  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13
 at ??:?
flux is offline   Reply With Quote
Old   April 28, 2014, 06:08
Olivier
olivierG is on a distinguished road
hello,
Which OF version do you use ?
Because if this is the 2.3, then your trouble may come from the mapFields tools. use older version for mapFields, od change the interpolation method.
regards,
olivier
olivierG is offline   Reply With Quote
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 03:36
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 14:29
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
