pimpleFoam strange results
Old   April 23, 2014, 14:11
Default pimpleFoam strange results
Giampaolo Cetraro
misklach is on a distinguished road
hello everyone,
I'm solving the laminar flow around a flat plate at 4deg angle of attack with pimpleFoam. I got strange results, do you know where they might come from?
case 102
nOuterCorrectors 3
nCorrectors 2
nNonOrthogonalCorrectors 2
Courant max = 0.5
case 104
nOuterCorrectors 6
nCorrectors 2
Courant max = 10
case 106
nOuterCorrectors 6
nCorrectors 2
Courant max = 5
The case 104, seems to be better than 102, because I added more nOuterCorrectors (but a very high Co)
But in case 106, with the same correctors and half Co, again the flow field is totally weird...
Any hint?
misklach is offline   Reply With Quote
Old   April 24, 2014, 17:59
Joachim Herb
jherb is on a distinguished road
Try much larger nOuterCorrectors and add residual control, see e.g. https://github.com/OpenFOAM/OpenFOAM...tem/fvSolution
(this is the only example in the tutorials using it, so don't care about the different solver rhoPimpleFoam)
jherb is offline   Reply With Quote
Modifying sonicFoam to run with variable timestep - strange results dalaron OpenFOAM Programming & Development 1 September 2, 2013 07:21
Strange DNS results LijieNPIC OpenFOAM 14 June 14, 2011 04:30
upwind schema strange results; Solution of Versteeg example differs from OpenFOAM sol idrama OpenFOAM 12 May 10, 2011 05:38
Newton Raphson - strange results Bren Main CFD Forum 5 February 11, 2009 10:47
Slip boundary condition giving strange results hemph OpenFOAM Running, Solving & CFD 3 January 18, 2007 05:15
