Accessing information about Volume Fraction of Phases
Old   April 30, 2014, 07:40
Default Accessing information about Volume Fraction of Phases
Paritosh Vasava
vasava will become famous soon enough
I want to write a new viscosity model where viscosity is also a function of volume fraction of one of the phases in a multiphase flow.
I have played a bit with CrossPowerLaw. I made some minor modifications and everything was nice. I understood that this piece of code does is the main equation for the viscosity model.
Foam::tmp<Foam::volScalarField>
Foam::viscosityModels::NewCrossPowerLaw::calcNu() const
    return (nu0_ - nuInf_)/(scalar(1) + pow(m_*strainRate(), n_)) + nuInf_;
My question is how do I add information about volume fraction of certain phase into this code?? For example I want to multiply the final viscosity with volume fraction of one of the phases.
My C++ skills are way too basic so you would also have to explain about changes in the header file.
Thanks!!
PS:
  1. I would use this with twoPhaseEulerFoam or multiphaseEulerFoam.
  2. I have openfoam 2.3.0
vasava is offline   Reply With Quote
Old   April 30, 2014, 12:06
Andrew Somorjai
massive_turbulence is on a distinguished road
Thanks!!
PS:
In the code which variable is the final viscosity?
I'm assuming it's
nuInf_
so you would create it (volume fraction)
double vol_frac = function_for_calculation_of_vol_frac();
and then plug it into the code
    return (nu0_ - nuInf_*vol_frac)/(scalar(1) + pow(m_*strainRate(), n_)) + nuInf_*vol_frac;
I'm not sure what the type for nuInf_ is. What file is this in by the way?
For the header file you would need to add the function for
if not then you would need to include the volume fraction calculation within the function Foam::viscosityModels::NewCrossPowerLaw::calcNu() and there's no need to change any header file.
massive_turbulence is offline   Reply With Quote
Old   May 2, 2014, 01:17
Paritosh Vasava
Thanks for your response.
This code as I mentioned is from CrossPowerLaw. I have included this code just for illustration. Right now I do not know how to include the information about the volume fraction of a phase.
Old   May 2, 2014, 11:45
Andrew Somorjai
How is the 'volume fraction of the phase' calculated though, surely there's a simple formula (I think I remember something about this from thermo)? You might be able to read data from a dat file using fstream although if time dependence is necessary or some other variable changes then the function call would get more difficult to implement.
openfoam, viscosity models
volume fraction in mixture model and VOF???? multiphase-flow FLUENT 4 August 7, 2014 10:35
InterFoam channel Flow runnig very slowly Wokl OpenFOAM Running, Solving & CFD 4 January 9, 2014 02:52
assuming Volume fraction water =0 to volume fraction=0.5 flow_CH FLUENT 9 December 16, 2013 12:29
Help on accessing volume fraction in mixture model achuneka FLUENT 8 September 4, 2009 06:22
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 10:46
