multiphase DyM solvers - velocities
Old   May 7, 2014, 10:20
Default multiphase DyM solvers - velocities
vigges is on a distinguished road
Hello all,
I'm dealing with interDyMFoam and compressibleInterDyMFoam for quite some time now. At a recent meeting, the question came up which velocity is calculated - relative or absolute.
In this specific case, a closed test tube filled with 50% liquid and 50% air will be "shaken" along the longitudinal axis according to a prescribed oscillation (non-sinusoidal).
Looking at lines 110 and 111 in compressibleInterDyMFoam.C, I find
                // Make the fluxes relative to the mesh motion
                fvc::makeRelative(phi, U);
So, I think the velocity vectors are being "transformed" into the moving reference system, here, the moving domain. Or at least I believe that in the end my output values represent the relative velocity U_rel = U_abs - U_domain, but I'm not entirely sure. In this case, U_domain represents the velocity with which my mesh is moving.
Maybe, someone is able to shed light on that matter. Thank you
vigges is offline   Reply With Quote
multiphase flow, relative velocity
Sample velocities for a multiphase problem emirust OpenFOAM Post-Processing 9 November 12, 2020 08:14
yPlusRAS & yPlusLES doesn't work for multiphase Solvers (e.g. twoLiquidMixingFoam) cfdonline2mohsen OpenFOAM Post-Processing 3 July 20, 2014 13:30
multiphase solvers alpha sweep not implemented romant OpenFOAM 9 January 5, 2012 10:28
Multiphase solvers Theory titio OpenFOAM Running, Solving & CFD 1 November 20, 2009 17:23
multiphase UDF, variables for phase velocities Kerem FLUENT 4 March 27, 2006 08:20
