nCorrectors & nNonOrthogonalCorrectors
Old   June 2, 2014, 08:24
Question nCorrectors & nNonOrthogonalCorrectors
T. Chourushi
Tushar@cfd is on a distinguished road
Dear ALL,
By reading different threads, it can be judged that "nCorrectors & nNonOrthogonalCorrectors" are the different numbers of iteration cycles within one "timestep" and user can enter value ranging from "0" to "n".
Queries:
(1) What is the significance of the term "nCorrectors"? How the incremental value for the mentioned term improves the solution?
(2) What is "nNonOrthogonalCorrectors"? How it corrects the non-orthogonality? How the solver understands the type of Correction depending upon its value: from "0" to "n"?
Tushar@cfd is offline   Reply With Quote
Old   June 3, 2014, 04:53
Onno
Kaskade is on a distinguished road
http://openfoamwiki.net/index.php/Op...hm_in_OpenFOAM
Best Practice Guidelines:
http://www.openfoamworkshop2013.org/...rvojeJasak.tar
Kaskade is offline   Reply With Quote
Old   June 3, 2014, 07:10
T. Chourushi
I read these, still It has not clear few doubts:
(1) In case of nCorrectors: How the incremental value for the mentioned term improves the solution?
(2) In case of nNonOrthogonalCorrectors:
How it corrects the non-orthogonality? depending upon its value: from "0" to "n"?
These numerals are "numbers of iteration cycles" that's fine. Where is the source code for the same?
Thanks in Advance
Old   June 3, 2014, 07:21
Onno
So far I've kept clear off the source code. But I suggest starting with the source code for pimpleFoam and going from there. Be aware that PIMPLE also includes nOuterCorrectors.
https://github.com/OpenFOAM/OpenFOAM...m/pimpleFoam.C
interFoam: timestep / mesh / PISO nCorrector dependency linch OpenFOAM Running, Solving & CFD 16 October 31, 2019 04:24
pimpleFoam for full transient problems? immortality OpenFOAM Running, Solving & CFD 17 February 9, 2017 03:42
What are the definitions of nOuterCorrectors and nCorrectors immortality OpenFOAM Running, Solving & CFD 9 June 13, 2016 06:31
PISO nCorrectors and fatal error jdkummer OpenFOAM Running, Solving & CFD 10 May 30, 2011 16:55
