reactingFoam for supersonic flow?
Old   July 3, 2014, 09:47
Default reactingFoam for supersonic flow?
hester is on a distinguished road
I like to use reactingFoam to simulate an ALD reactor. Since I reach velocities up to 450 m/s I like to know if reactingFoam can be used for supersonic flow. And if not, how can I implement such a capability? Where do I have to look in the source code to find out if a solver is suited for supersonic flow? Would rhoReactingFoam be a better choice?
Thanks in advance for any info!
hester
hester is offline   Reply With Quote
Old   July 4, 2014, 10:51
Bobby
babakflame is on a distinguished road
Greetings Hester
rhoReactingFoam is much better for fully compressible flows. Cause it solves the rho equation every time step. Although reactingFoam uses compressible schemes due to not solving rho equation, is not suitable for supersonic flows.
Although for non-reacting cases you can use sonicfoam too.
Regards
Bobi
babakflame is offline   Reply With Quote
Old   July 6, 2014, 05:15
Hello Bobi,
thank you for your fast answer. Since I have a reacting flow I will try rhoReactingFoam. It sounds very promising.
regards
hester
Old   December 18, 2014, 12:34
Jacopo
yaqb is on a distinguished road
Hi Hester - Did you managed to successfully use rhoReactingFoam for supersonic flows? I am dealing with the similar problem and would like to know the right track to follow.
yaqb is offline   Reply With Quote
Old   December 19, 2014, 07:24
Hello yagb,
I wasn't able to realise my simulation. My simulation looked fine at the beginning but got unstable due to supersonic flow at some point. There is probably a solution to it but I could not figure it out. Anyway, I think rhoReactingFoam is the appropriate solver for such problems.
I hope you are more successful!
regards
hester
Old   December 27, 2014, 13:45
Dmitry
dimaCFD is on a distinguished road
Hello Hester,
I would like to suggest to try my solver edcPisoFoam =) which is based on rhoReactingFoam and incorporates the Eddy Dissipation Concept with a detailed chemistry approach for the turbulence-chemistry interaction. I have finished my PhD related to OpenFOAM and turbulent combustion modeling with OpenFOAM this year using this solver, so it has good validation and references =)
You can download it for free from:
http://www.edcpisofoam.decgroup.org/
Thx, Dmitry
dimaCFD is offline   Reply With Quote
Old   February 8, 2015, 09:38
Hello Dmitry,
I’m currently not working on this project. If I find time I will continue and also look at your solver. Thanks for the tip!
regards
hester
Old   May 11, 2015, 15:13
Talking
Howar
Howard is on a distinguished road
HTML Code:
[HTML][HTML][HTML]
[/HTML][/HTML][/HTML]
Originally Posted by dimaCFD View Post
Hello Hester,
Thx, Dmitry
Hi, friend, I'm interested in this solver. I try to install your edcPisoFoam, but always have problem(as the pictures in attachment), could you give some suggestion? Thank you
Howard is offline   Reply With Quote
Old   June 6, 2016, 08:37
Post
Mukesh Adlak
Adlak is on a distinguished road
Originally Posted by hester View Post
Hello yagb,
regards
hester
I am working on mixing of H2 & air at supersonic speed. I tried rhoreactingfoam but at high speed it has stopped after some iteration can u send me ur files at mukesh22adlak@gmail.com
I am also trying for doing the same with sonicfoam but not successful yet.
Adlak is offline   Reply With Quote
Old   June 6, 2016, 12:47
Hello Mukesh,
I was not able to produce a working case, so rhoReactingFoam should probably not be used for supersonic flows - see comment from babakflame above. SonicFoam might work, but I have no experience with this solver.
I wish you good luck!
Old   June 6, 2016, 15:14
Mukesh Adlak
Originally Posted by babakflame View Post
Greetings Hester
Regards
Bobi
Can u tell me how should I modify the sonicfoam solver for mixing of H2 & air at supersonic speed ? If u did it then send me required files at mukesh22adlak@gmail.com
Old   August 4, 2016, 07:23
Mukesh Adlak
Greetings Hester
Regards
Bobi
rhoReactingFoam is good for compressible transonic/subsonic flows. But It is not working for supersonic flows. Can u tell me how to modify it for supersonic flows.
Old   September 22, 2021, 03:25
Hosam Alrefaie
HosamAlrefaie is on a distinguished road
Hi
it is not clear how to download or implement edcPisoFoam.
I am trying to use it because I heard that it has WSGGM model in it.
What I want is to get WSGGM radiation submodel.
HosamAlrefaie is offline   Reply With Quote
Different flow patterns in CFX and Fluent avi@lpsc CFX 6 April 17, 2012 01:22
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
