November 4, 2011, 14:38 |
Particle interaction in twoPhaseEulerFoam
Christos Altantzis
Rep Power: 14 |
Hello everyone,
Although I have been following the forum for some time, this is my first post. I have very recently switched my interest from combustion to multiphase flows. I intend to study dense particle-gas flows (fluidized bed gasifiers) and I am interested in open source software to do it. I came across the twoPhaseEulerFoam solver but unfortunately my C++ knowledge is still very limited and I have some questions concerning it. From what I have understood by following the code itself and the forum, the solver uses two approaches to describe the particle interactions, the powder modulus approach and the kinetic theory of granular flows approach. I) Concerning the powder modulus, if I am not wrong, the code uses the ppProperties to calculate the solids pressure. How are the solids shear stresses taken into account, if at all? II) When using the ppProperties, the alphaMax criterion is not fulfilled even if the packing limiter is employed (parameters taken from Bouilard et al., AIChe 1989). Has anybody experienced this problem before? III) The same problem occurs when I use the KTGF for the more detailed description of the particle collisions. The solution to this problem would be to use an extremely small time step? (The simulations conducted up to now employ dt=10^-6). Are there any other possible solutions? Am I doing something wrong? I am using the version 2.0.1 and I try to simulate toy problems without employing turbulence modeling. Thank you very much |
November 5, 2011, 13:25 |
#2 | |||
Alberto Passalacqua
Rep Power: 36 |
Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. Last edited by alberto; November 5, 2011 at 13:26. Reason: Added [quote] |
November 5, 2011, 14:04 |
Christos Altantzis
Rep Power: 14 |
Hi Alberto,
Thank you very much for your fast and to the point response. I will study your paper and the code in detail in order to understand the problem thoroughly. I will try to implement your ideas myself. I am currently trying to find an appropriate tool for simulating fluidized bed gasifiers and I started from open source software since I am much more favorable to them. I will try as much as possible not to work with commercial codes. Can I ask you another question. I saw in your paper that you have some experience with MFIX. What is your opinion about this tool? All the Best, Christos |
November 5, 2011, 16:07 |
#4 | |
Alberto Passalacqua
Rep Power: 36 |
In my opinion, the major limitation is the capability of dealing with complex geometries. However, in recent releases the cut-cell technique was implemented to try to overcome this problem. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
November 5, 2011, 16:37 |
Christos Altantzis
Rep Power: 14 |
Thanks for the information Alberto.
August 3, 2014, 05:25 |
#6 | |
sd
Rep Power: 11 |
I think I can get some idea that Im struggling last few days. Actually I am trying to simulate euler model for a gas-solid particles. At the 1st time, only passing through Air but Secondly with combustion reactions. for the first case I can use twoPhaseEuler but for the second case twoPhaseEuler doesn't work because of reactions. can you give some idea which solver or how I can fix this problem? |
August 3, 2014, 05:28 |
#7 | |
sd
Rep Power: 11 |
I think I can get some idea that Im struggling last few days. Actually I am trying to simulate euler model for a gas-solid particles. At the 1st time, only passing through Air but Secondly with combustion reactions. for the first case I can use twoPhaseEuler but for the second case twoPhaseEuler doesn't work because of reactions. can you give some idea which solver or how I can fix this problem? I have solution in fluent but can't understand how to forward in OpenFoam with this 2 conditions. |
gas-particle flows, twophaseeulerfoam |
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) | Julian K. | STAR-CCM+ | 2 | October 11, 2011 10:19 |
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) | Julian K. | CFX | 2 | September 15, 2011 15:30 |
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) | Julian K. | FLUENT | 0 | September 14, 2011 15:40 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
interaction time between particle and eddies | Steve | FLUENT | 0 | April 10, 2001 18:17 |
