Disabling Wall Functions
Like Tree1Likes
  • 1 Post By Kaskade
Old   February 10, 2012, 06:10
Default Disabling Wall Functions
Onno
Kaskade is on a distinguished road
I am trying to simulate a mesh containing walls with y+-Values between 100 and 200, as well as walls with y+-Values well below 1 using kOmegaSST.
Of course this is not really good to begin with but my idea was to use fixedValue for k and zeroGradient for omega on the walls with the low y+-Values.
Unfortunately when I start the simulation the OpenFOAM seems to set the walltypes to wallfunctions on it's own. Is there some way to disable this?
Kind regards
Kaskade
Kaskade is offline   Reply With Quote
Old   February 12, 2012, 13:59
Onno
Answer:
k
type fixedValue;
value 0; //some say you should use a value like 1e-11, but it doesn't seem to make any difference
omega
type zeroGradient;
nut
type calculated;
value $internalField;
If you don't set up a file for nut yourself, OpenFOAM will generate it and upgrade your walls with wallfunctions.
slint likes this.
Old   August 23, 2014, 04:30
Huang Xianbei
huangxianbei is on a distinguished road
Originally Posted by Kaskade View Post
Answer:
k
type fixedValue;
omega
type zeroGradient;
nut
type calculated;
Hi,Onno:
Why the nut is set to be calculated instead of zerogradient? I remember that when no wall function is needed, the type should be zerogradient. Please correct me if I'm wrong
Xianbei
huangxianbei is offline   Reply With Quote
Old   August 23, 2014, 04:48
Onno
That was a long time ago.... right now I what say, you might as well leave the wall functions turned on and use nutUSpaldingWallFunction for nut.
@myself from 2,5 years ago: If your mesh is that bad/uneven -> fix that first.
Old   August 23, 2014, 10:39
Huang Xianbei
Hi,Onno:
Thank you for your reply. As omega based turbulence model can solve the finer mesh with y+<3 or less, so no wall function is needed when the mesh is fine enough. What do you mean by saying 'turn on the wall function as well'?
Xianbei
Old   August 23, 2014, 12:19
Onno
In my original post I was asking for a way to turn of the wall function manually on walls with a small y+. But from I understand now, you don't need to turn off the wall functions, since omegaWallFunction and nutUSpaldingWallFunction can be used for small y+-values.
Old   August 24, 2014, 02:03
Huang Xianbei
I see, you mean it's a kind of automatic wall function similar to the commercial codes like CFX, right? Just not long before, I was confused about the wall function that there is no explicit y+ threshold in the source code. So the nuSgsWallFunction is similar to that of nutSpaldingwallfunction, which is also based on Spalding's law, right?
Old   August 24, 2014, 03:44
Onno
It think it is discussed here: http://www.cfd-online.com/Forums/ope...megasst-2.html
Old   August 24, 2014, 09:53
Huang Xianbei
Thank you very much. Now I know that the nut and nuSgs may be a generic wall function. So whatever the resolution of the mesh is , using a wall function will be better.
Wall functions - questions about implementation AlmostSurelyRob OpenFOAM Programming & Development 44 May 6, 2020 10:11
Modelling Turbulent Wall Functions victorwfreire CFX 11 January 14, 2015 15:48
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
Wall Functions pierre OpenFOAM Running, Solving & CFD 0 October 1, 2005 13:13
LES wall functions barrat Main CFD Forum 10 September 1, 2004 08:29
