Size of boundary layer
Old   September 11, 2014, 09:12
Default Size of boundary layer
Olivia Nalen
entropie is on a distinguished road
Hello dear Foamers,
I have a question about k-omega-SST turbulence model. There are two turb. models, connected in it; the one is for the boundary layer, and the other is for the other flow.
Does someone know "how large" is the boundary layer in case of a flow around an airfoil? It suppose to be infinite small, but I wonder how does this works in a OpenFoam simulation?
Sincerely, Olivia
entropie is offline   Reply With Quote
Old   September 12, 2014, 06:01
Julian Langowski
Ruli is on a distinguished road
Dear Olivia,
check out the book "Boundary-Layer Theory" by Schlichting & Gersten.
There you find everything on BL, including formulas for computing approximate BL thickness for flat plates. This value you can use as approximation of an airfoil`s BL.
Otherwise you can use XFOIL for BL thickness calculation.
Best regards
Julian
πάντα ῥεῖ - Heraclitus
Ruli is offline   Reply With Quote
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
