what is 'useReactionRate' in reactingFoam ??
Old   September 25, 2014, 14:47
Question what is 'useReactionRate' in reactingFoam ??
Harshad Lalit
harshad88 is on a distinguished road
Hello all,
I am still a newbie with OpenFoam. I want to know what does the boolean statement useReactionRate TRUE achieve when using the reactingFoam solver ??
Any help would be greatly appreciated. Thanks!
harshad88 is offline   Reply With Quote
Old   September 28, 2014, 14:38
Harshad Lalit
Anyone who can help?
Old   September 30, 2014, 03:44
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Assuming that you mean useReactionRate in PaSRCoeffs dictionary in constant/combustionProperties file (though it was non-trivial to figure this out), it has no direct connection with reactingFoam but it's a property of combustoin model.
If you go to src/combustionModels/PaSR and look as PaSR.C, you'll find there:
template<class Type>
void Foam::combustionModels::PaSR<Type>::correct()
    if (this->active())
        if (!useReactionRate_)
            this->chemistryPtr_->solve(t - dt, dt);
        else
            this->chemistryPtr_->calculate();
there type is defined by the line "combustionModel PaSR<psiChemistryCombustion>" in combustionProperties. Properties of psiChemistryCombustion are defined in chemistryProperties dictionary. If you then go to src/thermophysicalModels/chemistryModel/chemistryModel/basicChemistryModel and open basicChemistryModel.H file, you'll find the following code and comments:
            // Chemistry solution
                //- Calculates the reaction rates
                virtual void calculate() = 0;
                //- Solve the reaction system for the given start time and
                //  timestep and return the characteristic time
                virtual scalar solve(const scalar t0, const scalar deltaT) = 0;
Now you can use Doxygen generated documentation and sources to find concrete implementations of these methods.
alexeym is offline   Reply With Quote
Old   March 18, 2015, 10:10
Smile How to know the detail of the models and parameters? in reactingFoam
Howar
Howard is on a distinguished road
Originally Posted by alexeym View Post
    if (this->active())
        else
Thank you very much for your answer. I am new user of OpenFoam and I also try to understand the parametersn and the model uses in the reactiongFoam. Could you explain how to see the detail thing by 'Doxygen generated documentation and sources', I am not quite clear.
Howard is offline   Reply With Quote
Old   February 27, 2016, 11:05
Arrow reply
amin jalalian
amin_jalalian is on a distinguished road
Hi
the "useReactionRate" has been removed in OF301. It is not in src's files or other folder's, but it is in some tutorial files which is not true and their programmers forgot to remove that phrase from tutorials.
regards.
amin_jalalian is offline   Reply With Quote
Old   May 7, 2016, 04:39
amin jalalian
Originally Posted by amin_jalalian View Post
Hi
regards.
better:
Hi
the "useReactionRate" in has been removed in OF301. It is not in src's files or other folder's, but it is still in 3 tutorial files (file: combustionProperties) which is not right and it seems its programmers forgot to remove "useReactionRate" from tutorials.
regards.
Old   June 2, 2016, 11:27
Mr.liu
lx882211 is on a distinguished road
    if (this->active())
        else
I meet a problem in Openfoam 2.3.0, reactingFoam, i need the data of CH4 reaction rate, but i failed to autowrite it like U or Yi.
First i added this code in the CreatField.H,
volScalarField Rrate
IOobject
"Rrate",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar("Rrate", dimMass/dimVolume/dimTime, 0.0)
Then, i added this code in YEqn,
forAll(Y, i)
if (Y[i].name() != "CH4")
RR = reaction->R(Yi);
After wmake, it shows
YEqn.H:26:14: error: no match for ‘operator=’ (operand types are ‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ and ‘Foam::tmp<Foam::fvMatrix<double> >’)
Rrate = reaction->R(Yi);
Can you tell me how to do that? Thank you very much.
lx882211 is offline   Reply With Quote
calculate flame speed using reactingFoam IColin OpenFOAM Running, Solving & CFD 0 February 4, 2014 15:14
reactingFoam crashing rishibigghe OpenFOAM Running, Solving & CFD 0 June 14, 2011 17:50
Constant Volume Combustion with reactingFoam Alish1984 OpenFOAM Running, Solving & CFD 2 May 8, 2011 08:51
reactingFoam wedge handling wrong U dhondupant OpenFOAM Bugs 1 December 9, 2010 07:34
reactingFoam - turbulent reacting flow hamburgFoam OpenFOAM 0 December 7, 2009 12:57
